Meet cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1 error
• Hardware Platform (Jetson / GPU)-----GeForce GTX 1080 Ti
• DeepStream Version------5.0
• TensorRT Version-----7.1.3.4
• NVIDIA GPU Driver Version (valid for GPU only)----450.80.02
• Issue Type( questions, new requirements, bugs)—questions
HI, guys,
I am attempting to run an instance of deepstream demo on my PC under ubuntu18.04 with the following command:
./deepstream-test1-app …/…/…/…/samples/streams/sample_720p.h264
and the results as follows:
Now playing: …/…/…/…/samples/streams/sample_720p.h264
0:00:00.662060131 31115 0x560e544946d0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/home/xh/develop/local/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:00.662124180 31115 0x560e544946d0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /home/xh/develop/local/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:00.662804806 31115 0x560e544946d0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Running…
Frame Number = 0 Number of objects = 6 Vehicle Count = 4 Person Count = 2
0:00:00.955505302 31115 0x560e53765940 WARN nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:00.955524716 31115 0x560e53765940 WARN nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop: error: streaming stopped, reason not-negotiated (-4)
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: gstnvinfer.cpp(1975): gst_nvinfer_output_loop (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Frame Number = 1 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 2 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 3 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 4 Number of objects = 5 Vehicle Count = 3 Person Count = 2
Frame Number = 5 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Frame Number = 6 Number of objects = 6 Vehicle Count = 4 Person Count = 2
Deleting pipeline
I meet the same trouble as cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1. The difference is my environment is not a docker. what should i do to solve the problem? please help.
nvidia-smi
Wed Feb 3 17:10:56 2021
| NVIDIA-SMI 450.80.02 Driver Version: 450.80.02 CUDA Version: 11.0 |
| | | MIG M. |
| 0 GeForce GTX 108… Off | 00000000:67:00.0 Off | N/A |
| 21% 30C P8 10W / 250W | 3MiB / 11178MiB | 0% Default |
| | | N/A |
| 1 GeForce GTX 108… Off | 00000000:68:00.0 On | N/A |
| 21% 38C P8 16W / 250W | 234MiB / 11175MiB | 2% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 1 N/A N/A 12566 G gnome-control-center 2MiB |
| 1 N/A N/A 13757 G /usr/bin/gnome-shell 220MiB |
lspci -k |grep -A 2 -i “VGA”
67:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1)
Subsystem: Gigabyte Technology Co., Ltd GP102 [GeForce GTX 1080 Ti]
Kernel driver in use: nvidia
68:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1)
Can you check your opengl with “dpkg -l | grep -i opengl”?
