Hi Paolo,
Using derived types in CUDA Fortran can be a bit tricky since only the members of a type can have a “device” attribute. If the derived type object itself has a “device” attribute, then it couldn’t be accessed on the host and any allocations would have to be done on the device as well, which would be poor for performance. For example, if we did the following:
type mytype
real, allocatable, dimension(:,:,:),device :: f_
end type mytype
type(mytype),device :: u
allocate(u%f_(0:nx,ny,nz))
u%f_ = 2.0
The code would seg fault since “u” has a device address being dereferenced on the host when ever “u%f_” is used.
So while you could remove “device” from “u” and then pass in “f_” to a subroutine, the easier method is to use the “managed” attribute. “managed” uses CUDA Unified Memory where the same address is accessible on the host and device.
For example:
program test
use cudafor
implicit none
type mytype
real, allocatable, dimension(:,:,:),managed :: f_
end type mytype
type(mytype),managed :: u
real :: r
integer :: nx,ny,nz
integer :: i,j,k
r=2.0
nx=32
ny=32
nz=32
u%f_=2.0
!$cuf kernel do(3) <<<*,*>>>
do k=1,nz
do j=1,ny
do i=0,nx
u%f_(i,j,k) = u%f_(i,j,k) + r
end do
end do
end do
do i=0,nx
print *, u%f_(i,1,1),u%f_(i,ny,nz)
enddo
deallocate(u%f_)
end program test
Note, since module variables have global static storage and CUDA Unified Memory is only available for dynamic data, if “u” was declared in a module using “managed” wont work. Instead, you would need to declare “u” as an allocatable with the “managed” attribute and then when it’s allocated, it would use a unified address.
Hope this helps,
Mat
