Hi Sir,
We upgraded the TX1 from Jetpack 4.2 to Jetpack 4.3 and found the Memory Access issue.
In the meanwhile, we checked the NV forum and found there is a patch file Nvidia released for the TK1. We would like to check if there is a file for the TX1 to solve this kind of issue.
Below are our test steps and log file.
- Upgraded TX1 from Jetpack 4.2 to Jetpack 4.3
- Tested with our application, there were random system crash issues that happened during the testing process.
- Tested again but disabled our application. No system crash issues happened.
- Re-verified in disabling our application but with a Memory R/W testing program. System crashes again in the testing.
- We searched the NV forum and found there is a patch file for the TK1.
Happens within 2 hours and up on some units and 7-10 hours on others.
Fault looks like this.
1[26512.079272] Unable to handle kernel write to read-only memory at virtual address 00000008
2[26512.091888] Mem abort info:
3[26512.098550] ESR = 0x96000045
4[26512.101659] Exception class = DABT (current EL), IL = 32 bits
5[26512.107697] SET = 0, FnV = 0
6[26512.110843] EA = 0, S1PTW = 0
7[26512.114154] Data abort info:
8[26512.117349] ISV = 0, ISS = 0x00000045
9[26512.123082] CM = 0, WnR = 1
10[26512.126167] user pgtable: 4k pages, 39-bit VAs, pgd = ffffffc0cbde6000
11[26512.132900] [0000000000000008] *pgd=0000000000000000, *pud=0000000000000000
12[26512.140231] Internal error: Oops: 96000045 [#1] PREEMPT SMP
13[26512.145791] Modules linked in: fuse zram bcmdhd cfg80211 spidev nvgpu bluedroid_pm ip_tables x_tables
14[26512.155069] CPU: 3 PID: 12414 Comm: systemctl Not tainted 4.9.140-tegra #1
15[26512.161928] Hardware name: Jetson-TX1 (DT)
16[26512.166013] task: ffffffc03a9d9c00 task.stack: ffffffc0858cc000
17[26512.171925] PC is at unlink_anon_vmas+0xcc/0x230
18[26512.176531] LR is at unlink_anon_vmas+0xb8/0x230
19[26512.181136] pc : [<ffffff8008210cf4>] lr : [<ffffff8008210ce0>] pstate: 60400045
20[26512.188513] sp : ffffffc0858cfc80
21[26512.191817] x29: ffffffc0858cfc80 x28: ffffffc0378552d0
22[26512.197129] x27: 0000000000000001 x26: ffffff800a0831d4
23[26512.202441] x25: dead000000000100 x24: dead000000000200
24[26512.207751] x23: ffffffc039994580 x22: ffffffc0378552d0
25[26512.213064] x21: ffffffc0399945f8 x20: fffffffffffffff0
26[26512.218377] x19: ffffffc005e80040 x18: 00000000000005c3
27[26512.223688] x17: ffffffff00000001 x16: 0000000000000000
28[26512.229000] x15: 0000007fa931de08 x14: 0000007fa932b308
29[26512.234311] x13: 0000000000000000 x12: 0000000000000000
30[26512.239622] x11: ffffffc03a245880 x10: 00000055b9601000
31[26512.244935] x9 : ffffffc08ea13108 x8 : 0000000000000000
32[26512.250246] x7 : ffffffc005e80060 x6 : 0000007fa8e62000
33[26512.255556] x5 : 0000000000000000 x4 : ffffff800a167000
34[26512.260866] x3 : 0000000000000000 x2 : ffffffc0399945f8
35[26512.266175] x1 : ffffffc005e80040 x0 : ffffffc005e802e0
36[26512.271484]
37[26512.272970] Process systemctl (pid: 12414, stack limit = 0xffffffc0858cc000)
38[26512.280000] Call trace:
39[26512.282441] [<ffffff8008210cf4>] unlink_anon_vmas+0xcc/0x230
40[26512.288087] [<ffffff800820001c>] free_pgtables+0xcc/0x130
41[26512.293472] [<ffffff800820a8d4>] exit_mmap+0xac/0x118
42[26512.298512] [<ffffff80080b0548>] mmput+0x60/0x130
43[26512.303203] [<ffffff80080b961c>] do_exit+0x26c/0xa08
44[26512.308155] [<ffffff80080b9e48>] do_group_exit+0x40/0xa8
45[26512.313453] [<ffffff80080b9ed0>] __wake_up_parent+0x0/0x40
46[26512.318926] [<ffffff80080838c0>] el0_svc_naked+0x34/0x38
47[26512.324226] ---[ end trace f8476a12bd2f1ecd ]---
48[26512.337619] Fixing recursive fault but reboot is needed!
