Memory Access Problem
I am writing a code, but i find that it fails to compile even for the beginning part. The code looks like this:
[codebox]#include <stdio.h>
#include <stdlib.h>
#include “cutil_inline.h”
global void initial(float* u,int lengthx)
unsigned int thid=threadIdx.x+lengthx*blockIdx.x;
if(threadIdx.x<lengthx)
	u[thid]=1;
global void boundary(float* boundx0,float* boundx1,float* boundy0,float* boundy1,float* boundz0,float* boundz1,int lengthx,int lengthy,int lengthz)
unsigned int thidx=threadIdx.x+blockDim.x*blockIdx.x;
unsigned int thidy=threadIdx.y+blockDim.y*blockIdx.y;
if(thidx<lengthx&&thidy<lengthy)
	boundx0[thidx+thidy*lengthx]=0.1;
	boundx1[thidx+thidy*lengthx]=0.2;
	boundy0[thidx+thidy*lengthx]=0.3;
	boundy1[thidx+thidy*lengthx]=0.4;
	boundz0[thidx+thidy*lengthx]=0.5;
	boundz1[thidx+thidy*lengthx]=0.6;
int main(int argc, char* argv)
float*u,*boundx0,*boundx1,*boundy0,*boundy1,*boundz0,*boundz
1;
float*rhs,*a,*b,*c;
float alpha;
float*debug;
int lengthx=100,lengthy=100,lengthz=100;
int threads=128;
int blocks;
int slice;
int volume;
slice=threads*threads;
blocks=slice;
volume=slice*threads;
cudaMalloc((void**)&u,2097152*sizeof(float));
cudaMalloc((void**)&boundx0,slice*sizeof(float));
cudaMalloc((void**)&boundx1,slice*sizeof(float));
cudaMalloc((void**)&boundy0,slice*sizeof(float));
cudaMalloc((void**)&boundy1,slice*sizeof(float));
cudaMalloc((void**)&boundz0,slice*sizeof(float));
cudaMalloc((void**)&boundz1,slice*sizeof(float));
cudaMalloc((void**)&rhs,volume*sizeof(float));
cudaMalloc((void**)&a,threads*sizeof(float));
cudaMalloc((void**)&b,threads*sizeof(float));
cudaMalloc((void**)&c,threads*sizeof(float));
initial<<<blocks,threads>>>(u,lengthx);
cudaThreadSynchronize();
dim3 threads2D(16,16);
dim3 blocks2D(threads/16,threads/16);
boundary<<<blocks2D,threads2D>>>(boundx0,boundx1,boundy0,boundy1,boundz0,boundz1,lengthx,
lengthy,lengthz);
//Debug and Checking section
cudaMalloc((void**)&debug,volume*sizeof(float));
cudaMemcpy(debug,u,volume*sizeof(float),cudaMemcpyDeviceToHo
st);
FILE *fileid=fopen("output.txt","w");
for(int i=0;i<volume;i++)
	fprintf(fileid,"%f\n",debug[i]);
}[/codebox]
Visual studio complains that expression for u cant be evaluated…
What mistakes have i done?
Ok i must be dreaming when i wrote the code… :">
I accidentally use cudaMalloc to allocate memory for the host…
