I have a problem in the following code. I used dimGrid(1,1,1), dimBlock(21,21,0) in executing the kernel. The following code is where there are some memory access violations. I use the nsight debugging in VS2012, and the breakpoint is at
static forceinline int __float2int_rz(float in)
return __nv_float2int_rz(in);
int the device_function.h… So wired. Could any one help me on this? Many thanks in advance.
fInputa_dR[254254], fInputRx[254254], fInputRy[254254], iSubsetW = iSubsetH = 33, iNumberX = iNumberY = 21, fRDescent[33336], fdPXY[2121*2].
//Fill the gray intensity value to subset R
for(int l=0; l<iSubsetH; l++){
for(int m=0; m<iSubsetW; m++){
fSubsetR[l*iSubsetW+m] = fInput_dR[int(fdPXY[0] - iSubsetY+l)*width+int(fdPXY[1] - iSubsetX+m)];
fSubAveR += (fSubsetR[l*iSubsetW+m]/float(iSubsetH * iSubsetW));
//Evaluate the Jacobian dW/dp at(x,0)
fJacobian[0][0] = 1.0, fJacobian[0][1] = float(m-iSubsetX), fJacobian[0][2] = float(l-iSubsetY), fJacobian[0][3] = 0.0, fJacobian[0][4] = 0.0, fJacobian[0][5] = 0.0;
fJacobian[1][0] = 0.0, fJacobian[1][1] = 0.0, fJacobian[1][2] = 0.0, fJacobian[1][3] = 1.0, fJacobian[1][4] = float(m-iSubsetX), fJacobian[1][5] = float(l-iSubsetY);
for(int k=0; k<6; k++){
fRDescent[(l*iSubsetW+m)*6+k] = fInput_dRx[int(fdPXY[0] - iSubsetY+l)*width+int(fdPXY[1] - iSubsetX+m)]*fJacobian[0][k]
+fInput_dRy[int(fdPXY[0] - iSubsetY+l)*width+int(fdPXY[1] - iSubsetX+m)]*fJacobian[1][k];
for(int n=0; n<6; n++){
fHessianXY[k][n] = fRDescent[(l*iSubsetW+m)*6+k] * fRDescent[(l*iSubsetW+m)*6+n];//Hessian matrix at each point
fHessian[k][n] += fHessianXY[k][n];
