I’m trying to use cusolverSpDcsrlsvchol() to solve a matrix with 1m*1m size and 5m non-zero. However, the function returns CUSOLVER_STATUS_ALLOC_FAILED. It means the memory allocation is failed in that function.
I wonder if there’s a way to solve this problem. Or is there a way to know how much more memory I need for this function?
The error you are hitting may be indicative of a limitation in the algorithm, when there is a large zero fill-in on the G matrix. Having more memory would not allow you to work around this limitation.
“Remark 2: the function only works on 32-bit index, if matrix G has large zero fill-in such that number of nonzeros is bigger than 2 31 , then CUSOLVER_STATUS_ALLOC_FAILED is returned.”
Well, in that case I would strongly encourage your CUDA development team to implement the cusolver version with 64-bit integers, because current version is pretty useless for solving any problems that take more than a few seconds.
Consider filing an enhancement request via the bug reporting pade. Prefix the synopsis with “RFE:” to mark it as an enhancement request.
Filing an enhancement request doesn’t guarantee that a desired feature will materialize any time soon, but without filing of an enhancement request the likelihood is high that it will never come into existence.
Agree, the enhancement request is a good way to get your voice heard.
Also, the limitation on 32-bit integers for double quantities translates to a limit of 16GB for the temporary storage (really, potentially larger than that, as I am only considering the non-zero values here, no other arrays such as indexing). 64-bit integers wouldn’t dramatically change the possible sizes, even on the largest of GPUs, currently.
On your 12GB titan, if the zero fill-in is hitting the ceiling, the ceiling it is hitting is your memory size, not the 32-bit integer limitation.
Since there are no provided examples in this thread, it is impossible to know if zero fill-in is actually the problem (or what the problem actually is), as that depends on matrix structure, which cannot be inferred from simple descriptions like dimensions or the number of non-zeros.
