HW : Jetson NX devkit
purpose : run object detection example code with remote camera (need to use openCV)
here is my code modified from example code.
import cv2
import jetson.inference
import jetson.utils
import numpy as np
camera = cv2.VideoCapture(‘http://10.42.0.80:8090’) #remote cam url
camera = cv2.VideoCapture(0)
net = jetson.inference.detectNet(“ssd-mobilenet-v2”, threshold=0.5)
_,img = camera.read()
width = np.shape(img)[1]
height = np.shape(img)[0]
print(“\n debug 1\n”)
input_img = jetson.utils.cudaFromNumpy(img)
print(“\n debug 2\n”)
detections = net.Detect(input_img,width,height)
print("detections : ",detections)
In my opinion,
The problem seem to be in this line.
The error below occurs.
Cuda Error in allocateContextResources: 700 (an illegal memory access was encountered)
If the “jetson.utils.cudaFromNumpy” command is run correctly,
python script need to show the following result
I think an error occurred because the cuda memory could not
be free due to an unknown problem.
How can I solve this problem?
Full error code of above code
debug 1
jetson.utils – cudaFromNumpy() ndarray dim 0 = 480
jetson.utils – cudaFromNumpy() ndarray dim 1 = 640
jetson.utils – cudaFromNumpy() ndarray dim 2 = 3
debug 2
[TRT] …/rtSafe/cuda/caskConvolutionRunner.cpp (317) - Cuda Error in allocateContextResources: 700 (an illegal memory access was encountered)
[TRT] FAILED_EXECUTION: std::exception
[TRT] detectNet::Detect() – failed to execute TensorRT context
File “test3.py”, line 16, in
Exception: jetson.inference – detectNet.Detect() encountered an error classifying the image
PyTensorNet_Dealloc()
[cuda] cudaFreeHost(mDetectionSets[0])
[cuda] an illegal memory access was encountered (error 700) (hex 0x2BC)
[cuda] /home/user/jetson-inference/c/detectNet.cpp:66
[cuda] cudaFreeHost(mClassColors[0])
[cuda] /home/user/jetson-inference/c/detectNet.cpp:74
gridAnchorPlugin.cpp, 162, 700
gridAnchorPlugin.cpp, 163, 700
gridAnchorPlugin.cpp, 166, 700
gridAnchorPlugin.cpp, 167, 700
gridAnchorPlugin.cpp, 168, 700
[TRT] …/rtExt/cuda/cudaFusedConvActRunner.cpp (90) - Cuda Error in destroyFilterTexture: 700 (an illegal memory access was encountered)
[TRT] INTERNAL_ERROR: std::exception
[TRT] …/rtSafe/safeRuntime.cpp (32) - Cuda Error in free: 700 (an illegal memory access was encountered)
terminate called after throwing an instance of ‘nvinfer1::CudaError’
what(): std::exception
Aborted (core dumped)
