Hi
I have got a Quadro FX 5600 with 1.5GB global memory.
I’m trying to create a volume renderer for a quite big volume, based on the “volume renderer” example included in CUDA SDK’s projects.
As can be seen in the attached source (based on original CUDA’s “volume renderer” sample), I have got 2 big memory allocations to do on the device, both made by cudaMalloc:
- A constant allocation of ~40MB
- A memory block describing the whole volume which can get up to 460MB. This memory is then bound to a uchar texture in the same way it’s done in CUDA’s “volume renderer” project.
No other significant memory is allocated on the device.
When I try to allocate quite small volumes (I’ve checked up to 110MB), it works fine, but when I try to allocate bigger volumes, I get no error message on runtime but the software doesn’t work.
Does anybody have any idea what may be the problem?
volumeRender_kernel.cu.txt (6.13 KB)
volumeRender.cu.txt (14.2 KB)
