Based on different functions, some fraction of the local memory BW is used by the application. Is there a document with either analysis or BW used by different functions?
If I need to add more frame based processing for computer vision, how to confirm I am not hitting the max limits of the local memory BW?
Do you mean memory usage? Suppose Memory bandwidth is depend on the memory clocks cat get from below sysfs node.
sudo cat /sys/kernel/debug/bpmp/debug/clk/emc/rate
