Need to generate the parameter file for Micron chip MT41K256M16LY-107:N
Referring the parameter file in extras\param_files directory. In parameter file, under //Tool options,
some parameters are there. E.g.
// Tool options
allow_la_dda_cfg : 0 // Add LA/DDA programming as part of BOOT_LOADED boot_mode
dram_board_cfg : DF // DRAM board swizzle configuration
dqm_inverted : DF // Control to invert dqm
dqs_pulld_en : DF // force dqs pulldown. DF means only high freq turns it on
odt_en : DF // force odt enable. DF means only high freq turns it on
share_one_odt : DF // force share one odt.
dll_en : DF // force dll enable. DF means dll is always enabled
lock_dll_b4_cc : DF // lock dll before clock change
dll_cont : 0 // force dll mode to be continuous.
dll_ovr : DF // force dll override enable.
dll_override_val : DF // dll override value.
and etc.
Whether we need to update these parameters or directly use the reference chip parameters.
What kind of change, need to make? Please help.
