• Hardware Platform (Jetson / GPU) two 3090 RTX
• DeepStream Version 9.0
• TensorRT Version deepstram installation guide
• NVIDIA GPU Driver Version (valid for GPU only) 590
I am running a DeepStream pipeline on a system with two GPUs. My intended configuration is:
- GPU 1:
nvurisrcbinand hardware decoding - GPU 0:
nvstreammuxand the remaining downstream elements
However, the pipeline stops with the following error:
Memory Compatibility Error: Input surface gpu-id doesn't match with
configured gpu-id for element. Please allocate input using unified memory,
use the same gpu-ids, or, if the same gpu-ids are used, ensure appropriate
CUDA memory types are used.
gstnvstreammux.cpp(390): blit_buffer():
/GstPipeline:deepstream-pipeline-.../
GstNvStreamMux:nvstreammux-...-stream_muxer
According to the attached DOT graph, the source is configured as follows:
nvurisrcbin:
gpu-id=1
cudadec-memtype=memtype_unified
nvstreammux
nvbuf-memory-type=nvbuf-mem-cuda-unified
I also found the internal nvv4l2decoder0 element and manually set its cudadec-memtype to unified memory. However, the same GPU-ID mismatch error still occurs.
