• Hardware Platform (Jetson / GPU) rtx3050
• DeepStream Version 6.2
• TensorRT Version official deepstream 6.2 docker image
• NVIDIA GPU Driver Version (valid for GPU only) NVIDIA-Linux-x86_64-535.86.05
• Issue Type( questions, new requirements, bugs) bugs
Only do some config modification with python demo “deepstream_nvdsanalytics.py”. I run the application with 16 rtsp streams and with yolov8 model(fp16) for almost a day, and the memory increased about 50mb. Is this an obvious memory leak or not?
Another problem is the pipeline will definitely crash after running for about a day with no logs(may be logs in the console output but I can only see the logging file) while the computer memory is enough, this is a serious problem in production use. How to solve it?
Thank you!
this is the memory monitor log:
2023-08-06-23:33:08
VmRSS: 1899216 kB
VmSize: 21025980 kB
2023-08-07-20:46:51
VmRSS: 1949432 kB
VmSize: 21025980 kB
2023-08-07-23:11:22
VmRSS: 1952336 kB
VmSize: 21025980 kB
53120/1024=51mb
this is the gpu monitor log:
#Date Time gpu fb bar1 ccpm sm mem enc dec jpg ofa
#YYYYMMDD HH:MM:SS Idx MB MB MB % % % % % %
20230806 23:24:56 0 1 1 0 0 0 0 0 0 0
20230806 23:25:01 0 1 1 0 0 0 0 0 0 0
20230806 23:25:06 0 187 4 0 0 0 0 0 0 0
20230806 23:25:11 0 1679 6 0 44 22 5 21 0 0
20230806 23:25:16 0 1679 6 0 75 48 4 24 0 0
20230807 23:11:24 0 1679 6 0 76 47 6 33 0 0
20230807 23:11:29 0 1679 6 0 78 47 6 30 0 0
20230807 23:11:34 0 1679 6 0 75 43 5 30 0 0
20230807 23:11:39 0 1679 6 0 78 48 6 31 0 0
20230807 23:11:44 0 1679 6 0 80 48 6 31 0 0
20230807 23:11:49 0 1679 6 0 83 53 6 28 0 0
20230807 23:11:54 0 1 1 0 0 0 0 0 0 0
fanzh
August 8, 2023, 1:51pm
3
please refer to this topic . Setting rtspsrc drop-on-latency can improve.
I have already set the drop-on-latency to True with the above test。
how about the crash issue? cpu,gpu,memory all seems ok
Hi fanzh:
I use (GST_DEBUG=3 GST_DEBUG_FILE=/opt/ds/dbg.log ./app) this time with fake sink, the app runs abount 29 hours before crash.
this is the console output when crash:
**(python3:2821): GStreamer-CRITICAL : 11:37:35.176: gst_buffer_get_sizes_range: assertion ‘GST_IS_BUFFER (buffer)’ failed
there are gpu and memory logs
mem.log.tar.gz (28.1 KB)
gpu.log.tar.gz (307.4 KB)
**This is the lastest log from gdb.log when it’'s crash, without any crash stack **
29:29:10.684041781 ^[[332m 2821^[[00m 0x7fe64800e120 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:58.751384888 < 29:28:58.783523749)
29:29:10.684357709 ^[[332m 2821^[[00m 0x7fe67c0038c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:58.752288761 < 29:28:58.784413569)
29:29:10.686610605 ^[[332m 2821^[[00m 0x7fe64001ef60 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:58.752198025 < 29:28:58.784318951)
29:29:10.686669715 ^[[332m 2821^[[00m 0x7fe58401ee40 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:58.751691648 < 29:28:58.783831602)
29:29:10.686832809 ^[[332m 2821^[[00m 0x7fe58401f640 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:58.751345432 < 29:28:58.783483145)
29:29:11.316017992 ^[[332m 2821^[[00m 0x7fe63c02f0c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:59.559720303 < 29:28:59.593041577)
29:29:11.316061834 ^[[332m 2821^[[00m 0x7fe63000baa0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:59.559913710 < 29:28:59.593235556)
29:29:11.670578831 ^[[332m 2821^[[00m 0x7fe64800e120 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:59.783100835 < 29:28:59.815495469)
29:29:11.671574035 ^[[332m 2821^[[00m 0x7fe58401f640 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:59.783091862 < 29:28:59.815485594)
29:29:11.677084949 ^[[332m 2821^[[00m 0x7fe67c0038c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:59.784377804 < 29:28:59.816761395)
29:29:11.677173544 ^[[332m 2821^[[00m 0x7fe6d0009580 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:59.784366001 < 29:28:59.816748356)
29:29:11.677282607 ^[[332m 2821^[[00m 0x7fe58401ee40 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:59.783378567 < 29:28:59.815774061)
29:29:11.677647697 ^[[332m 2821^[[00m 0x7fe64001ef60 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:28:59.784390141 < 29:28:59.816770681)
29:29:12.343844286 ^[[332m 2821^[[00m 0x7fe63000baa0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:00.559771461 < 29:29:00.593109004)
29:29:12.344719276 ^[[332m 2821^[[00m 0x7fe63c02f0c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:00.559634133 < 29:29:00.592970016)
29:29:12.686489201 ^[[332m 2821^[[00m 0x7fe58401f640 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:00.807648836 < 29:29:00.840260395)
29:29:12.686581864 ^[[332m 2821^[[00m 0x7fe67c0038c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:00.809309485 < 29:29:00.841908866)
29:29:12.686749195 ^[[332m 2821^[[00m 0x7fe64001ef60 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:00.809350102 < 29:29:00.841949206)
29:29:12.687075954 ^[[332m 2821^[[00m 0x7fe64800e120 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:00.807633224 < 29:29:00.840245658)
29:29:12.687249327 ^[[332m 2821^[[00m 0x7fe6d0009580 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:00.809342535 < 29:29:00.841940478)
29:29:12.689884425 ^[[332m 2821^[[00m 0x7fe58401ee40 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:00.807870254 < 29:29:00.840483989)
29:29:12.875434767 ^[[332m 2821^[[00m 0x7fe654003300 ^[[31;01mERROR ^[[00m ^[[00;04m default gstrtspconnection.c:1046:gst_rtsp_connection_connect_with_response:^[[00m failed to connect: Could not connect to 192.168.2.252: No route to host
29:29:12.875460395 ^[[332m 2821^[[00m 0x7fe654003300 ^[[31;01mERROR ^[[00m ^[[00m rtspsrc gstrtspsrc.c:5047:gst_rtsp_conninfo_connect:^[[00m Could not connect to server. (Generic error)
29:29:12.875469532 ^[[332m 2821^[[00m 0x7fe654003300 ^[[33;01mWARN ^[[00m ^[[00m rtspsrc gstrtspsrc.c:7893:gst_rtspsrc_retrieve_sdp:^[[00m error: Failed to connect. (Generic error)
29:29:12.875509005 ^[[332m 2821^[[00m 0x7fe654003300 ^[[33;01mWARN ^[[00m ^[[00m rtspsrc gstrtspsrc.c:7973:gst_rtspsrc_open:^[[00m can’t get sdp
29:29:12.875519084 ^[[332m 2821^[[00m 0x7fe654003300 ^[[33;01mWARN ^[[00m ^[[00m rtspsrc gstrtspsrc.c:8512:gst_rtspsrc_play:^[[00m failed to open stream
29:29:12.875529544 ^[[332m 2821^[[00m 0x7fe654003300 ^[[33;01mWARN ^[[00m ^[[00m rtspsrc gstrtspsrc.c:6032:gst_rtspsrc_loop:^[[00m we are not connected
29:29:12.875550553 ^[[332m 2821^[[00m 0x7fe5ac068410 ^[[33;01mWARN ^[[00m ^[[00m discoverer gstdiscoverer.c:1591:handle_message:^[[00m Got an error [debug:gstrtspsrc.c(7893): gst_rtspsrc_retrieve_sdp (): /GstPipeline:Discoverer/GstURIDecodeBin:discoverer-uri/GstRTSPSrc:source:
Failed to connect. (Generic error)], [message:Could not open resource for reading and writing.]
29:29:12.875676678 ^[[332m 2821^[[00m 0x7fe654003300 ^[[33;01mWARN ^[[00m ^[[00m rtspsrc gstrtspsrc.c:6032:gst_rtspsrc_loop:^[[00m we are not connected
29:29:13.300173114 ^[[332m 2821^[[00m 0x7fe63000baa0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:01.559659674 < 29:29:01.592996316)
29:29:13.354479241 ^[[332m 2821^[[00m 0x7fe63c02f0c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:01.559566417 < 29:29:01.592901754)
29:29:13.649957547 ^[[332m 2821^[[00m 0x7fe58401f640 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:01.826813574 < 29:29:01.859579688)
29:29:13.658305054 ^[[332m 2821^[[00m 0x7fe58401ee40 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:01.826977220 < 29:29:01.859745043)
29:29:13.713610062 ^[[332m 2821^[[00m 0x7fe64800e120 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:01.826774742 < 29:29:01.859541543)
29:29:13.713610092 ^[[332m 2821^[[00m 0x7fe64001ef60 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:01.828792601 < 29:29:01.861557572)
29:29:13.713902256 ^[[332m 2821^[[00m 0x7fe67c0038c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:01.828750178 < 29:29:01.861514461)
29:29:13.714208957 ^[[332m 2821^[[00m 0x7fe6d0009580 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:01.828812951 < 29:29:01.861577484)
29:29:14.334669592 ^[[332m 2821^[[00m 0x7fe63000baa0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:02.559625450 < 29:29:02.592959796)
29:29:14.334676014 ^[[332m 2821^[[00m 0x7fe63c02f0c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:02.559565302 < 29:29:02.592898668)
29:29:14.684190214 ^[[332m 2821^[[00m 0x7fe58401ee40 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:02.842110192 < 29:29:02.874993956)
29:29:14.688461119 ^[[332m 2821^[[00m 0x7fe64800e120 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:02.841962816 < 29:29:02.874844549)
29:29:14.688517163 ^[[332m 2821^[[00m 0x7fe64001ef60 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:02.843883877 < 29:29:02.876770552)
29:29:14.688704672 ^[[332m 2821^[[00m 0x7fe67c0038c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:02.843859732 < 29:29:02.876745866)
29:29:14.688781265 ^[[332m 2821^[[00m 0x7fe58401f640 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:02.841993207 < 29:29:02.874875572)
29:29:14.688903352 ^[[332m 2821^[[00m 0x7fe6d0009580 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:02.843915872 < 29:29:02.876802203)
29:29:15.306095340 ^[[332m 2821^[[00m 0x7fe63c02f0c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:03.559788453 < 29:29:03.593114648)
29:29:15.306357378 ^[[332m 2821^[[00m 0x7fe63000baa0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:03.559861069 < 29:29:03.593186804)
29:29:15.665368106 ^[[332m 2821^[[00m 0x7fe58401f640 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:03.854117307 < 29:29:03.887083956)
29:29:15.672252999 ^[[332m 2821^[[00m 0x7fe64800e120 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:03.854090565 < 29:29:03.887057543)
29:29:15.672253009 ^[[332m 2821^[[00m 0x7fe64001ef60 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:03.855908690 < 29:29:03.888878263)
29:29:15.672299636 ^[[332m 2821^[[00m 0x7fe6d0009580 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:03.855946863 < 29:29:03.888916526)
29:29:15.672708568 ^[[332m 2821^[[00m 0x7fe58401ee40 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:03.854215868 < 29:29:03.887182743)
29:29:15.672783808 ^[[332m 2821^[[00m 0x7fe67c0038c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:03.855894711 < 29:29:03.888864955)
29:29:16.332109491 ^[[332m 2821^[[00m 0x7fe63c02f0c0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:04.559821199 < 29:29:04.593154869)
29:29:16.332303663 ^[[332m 2821^[[00m 0x7fe63000baa0 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:04.559910591 < 29:29:04.593243727)
29:29:16.672725037 ^[[332m 2821^[[00m 0x7fe58401f640 ^[[33;01mWARN ^[[00m ^[[00m videodecoder gstvideodecoder.c:2761:gst_video_decoder_prepare_finish_frame:^[[00m decreasing timestamp (29:29:04.863812987 < 29:29:04.896878390)
Ignore the connection error because one camera is down during the test.
If I use nvurisrcbin with file://xxx , the gdb log shows no warnings. But if use rtsp source. log shows
0:01:10.554519748 7605 0x7f4950044980 WARN v4l2videodec gstv4l2videodec.c:1315:gst_v4l2_video_dec_loop: Decoder is producing too many buffers
Is that the cause of crash?
• Hardware Platform (Jetson / GPU) gpu
• DeepStream Version 6.1.1
• TensorRT Version latest for ngc container
• NVIDIA GPU Driver Version (valid for GPU only) 515
• Issue Type( questions, new requirements, bugs) help
I’m having issues with artefacts on my image. In my setup…
The above topic may face the same issue .
After another two day test.
the crash problems occured when If use GitHub - bluenviron/mediamtx: Ready-to-use SRT / WebRTC / RTSP / RTMP / LL-HLS / MPEG-TS / RTP media server and media proxy that allows to read, publish, proxy, record and playback video and audio streams. · GitHub for rtsp server.
But if I use real IP camera, the app has running for two days not crash. I am still watching..
fanzh
August 13, 2023, 3:06pm
9
Thanks for the update.
from the log “mem.log.tar.gz”, there is no obvious memory leak. here is the key log:
2023-08-08-14:03:49
VmRSS: 1935108 kB
VmSize: 21474772 kB
2023-08-09-19:37:06
VmRSS: 2000328 kB
VmSize: 21417588 kB
it is Gstreamer warning logs. please refer to Gstreamer code.
[quote=“shao77622, post:6, topic:262325”]
[/quote
when using gdb to debug, can you try “bt” to get the current call stack? and can you use “thread apply all bt” to get all thread 's call stack?
do you have any new findings? Thanks!
The rtsp source cause this problem. Ip Camera rtsp source run without memory leak and crash. Solved
system
Closed
August 27, 2023, 3:36pm
11
