Memory controller error logging driver: backport to JetPack 7 R38.x?
Ketan Patil’s 6-patch series “memory: tegra: Add Tegra264 MC error logging support”
landed in Linux mainline v7.1-rc1 on 2026-03-07. It adds an EDAC-style driver
covering the MC + MSS_HUB + MC_CH + MCF error windows on Tegra264.
L4T R38.2.2 ships kernel 6.8.12 without this driver, so right now the only way
I’m getting at MC errors on Thor is reading the register space directly or
watching kernel printks.
Two questions:
  1. Is the series queued for an R38.x dot release, or only the next major L4T?
  2. If not queued for R38.x — would backporting it locally as an out-of-tree
    DKMS module against the L4T 6.8.12 source tree be expected to just work,
    or does the in-tree integration depend on changes that aren’t in the L4T
    kernel?
Trying to avoid duplicating work if it’s already on the roadmap.
Module: Jetson AGX Thor Developer Kit
L4T: R38.2.2
Kernel: 6.8.12-tegra
Looks like the solution already update to upstream.
Do you verify on JP7.1(r38.4)?
Thanks — yes, I saw the series landed upstream in v7.1-rc1. I haven’t verified on R38.4 yet; this unit is still on R38.2.2 (JetPack 7.0).
Before I move it, a practical question on the upgrade path itself: for AGX Thor, is apt-based OTA supported for JetPack 7.x minor upgrades (7.0 → 7.1, and later → 7.2), or does each minor release need a full SDK Manager / ISO reflash? I couldn’t find a documented 7.x apt-OTA procedure — the apt-OTA docs only cover 6.x — and the R38.4 notes describe the 38.2.x → 38.4 transition via ISO reinstall plus the UEFI display-handoff change, which reads like a reflash rather than in-place.
Why it matters: this is a deployed unit, so if 7.x → 7.x is reflash-only I’d rather wait and do a single reflash to 7.2 when it’s out than reflash for 7.1 now and again for 7.2 which is rumored to be released in early June.
Once it’s on R38.4 (or 7.2) I’ll check whether the tegra264 MC error-logging driver is present — lsmod / dmesg / the EDAC sysfs nodes — and report back here.
When r38.4 was released all I did was edit /etc/apt/sources.list.d/nvidia-l4t-apt-source.list
and change the three entries from 38.2 to 38.4
and sudo apt update && sudo apt upgrade
deb https://repo.download.nvidia.com/jetson/common r38.4 main
deb https://repo.download.nvidia.com/jetson/som r38.4 main
deb https://repo.download.nvidia.com/jetson/ffmpeg r38.4 main
