I am facing a Device memory corruption when trying to use the ‘cudnnRNNForward’ method (available in cuDNN 8)
with a data layout set to CUDNN_RNN_DATA_LAYOUT_BATCH_MAJOR_UNPACKED (cudnnRNNDataLayout_t).
I have no issues when using the CUDNN_RNN_DATA_LAYOUT_SEQ_MAJOR_UNPACKED layout.
We can use a very small input/output to reproduce the issue, as described below:
CUDA 11.0 on Windows 10 / x64
- cuda_11.0.1_451.22_win10.exe
cuDNN 8.0.5
- cudnn-11.0-windows-x64-v8.0.5.39.zip
simple unidirectional RNN (no LSTM /no GRU)
input ‘x’ shape for the cudnnRNNForward method: (1,1,1)
- timeSteps == batchSize == inputSize == 1
output ‘y’ shape for the cudnnRNNForward method: (1,1,1)
- timeSteps == batchSize == hiddenSize == 1
pseudo code to create the cudnnRNNDescriptor_t:
- cudnnCreateRNNDescriptor(cudnnRNNDescriptor_t* rnnDesc)
- cudnnSetRNNDescriptor_v8(rnnDesc, CUDNN_RNN_ALGO_STANDARD, CUDNN_RNN_TANH, CUDNN_RNN_SINGLE_INP_BIAS, CUDNN_UNIDIRECTIONAL, CUDNN_LINEAR_INPUT, CUDNN_DATA_FLOAT, CUDNN_DATA_FLOAT, CUDNN_DEFAULT_MATH, 1, 1, 1, 1, 0.0, CUDNN_RNN_PADDED_IO_ENABLED);
pseudo code to create the ‘cudnnRNNDataDescriptor_t’ associate with ‘x’ and ‘y’
- cudnnCreateRNNDataDescriptor(cudnnRNNDataDescriptor_t * RNNDataDesc)
cudnnSetRNNDataDescriptor(RNNDataDesc, CUDNN_DATA_FLOAT, CUDNN_RNN_DATA_LAYOUT_BATCH_MAJOR_UNPACKED , 1, 1, 1, [1], &paddingFill);
where:- [1] is an array of 1 integer element containing ‘1’
- paddingFill is a float with 0;
in the cudnnRNNForward call:
- ‘cudnnForwardMode_t fwdMode’ parameter is set to CUDNN_FWD_MODE_INFERENCE
- parameters releated to LSTM are let empty (null), we are only using a simple unidirectional RNN
For such a set up (with timeSteps == batchSize == inputSize == hiddenSize == 1),
I would have expected the 2 data layouts (CUDNN_RNN_DATA_LAYOUT_BATCH_MAJOR_UNPACKED & CUDNN_RNN_DATA_LAYOUT_SEQ_MAJOR_UNPACKED)
to behave the same in cudnnRNNForward method,
but it doesn’t seems to be the case:
CUDNN_RNN_DATA_LAYOUT_SEQ_MAJOR_UNPACKED is working OK (both inference & training)
API log: ok_with_CUDNN_RNN_DATA_LAYOUT_SEQ_MAJOR_UNPACKED.zip (2.6 KB)
It is also working OK with all other input shapes I tried -
CUDNN_RNN_DATA_LAYOUT_BATCH_MAJOR_UNPACKED is not working (device memory corruption issues)
API log: ko_with_CUDNN_RNN_DATA_LAYOUT_BATCH_MAJOR_UNPACKED.zip (1.5 KB)
It is also not working with all other shapes I tried
If you have already used CUDNN_RNN_DATA_LAYOUT_BATCH_MAJOR_UNPACKED layout with the cudnnRNNForward method,
I would be very thankful for your help.
Thank you.
Franck
