Memory fragmentation after allocation of small block of memory
I have the following problem with my GTX970 (4GB). After some allocations, the memory is highly fragmented after allocation of a small block of memory (8kb). I use the following code to reproduce the effect (compiled 64bit)
#include "cuda_runtime.h"
#include <stdio.h>
#include <vector>
size_t getLargestFreeBlock(std::vector<void*>& allocatedBlocks)
    void* block;
    size_t lastAllocableBlockSize = 0;
    size_t currentBlockSize = (size_t)8*1024*1024;
    size_t currentStepSize = currentBlockSize/2;
    do
        cudaError_t err = cudaMalloc (&block, currentBlockSize*1024);
        if ( err == cudaSuccess )
            lastAllocableBlockSize = currentBlockSize;
            cudaFree (block);
            currentBlockSize += currentStepSize;
        else
            currentBlockSize -= currentStepSize;
        currentStepSize >>= 1;
    } while (currentStepSize>0);
    cudaMalloc (&block, lastAllocableBlockSize*1024);
    allocatedBlocks.push_back (block);
    return lastAllocableBlockSize*1024;
void printFreeCudaMem()
    std::vector<void*> allocatedBlocks;
    size_t allocatedTotal = 0;
    printf("\nChecking memory:\n");
    do
        size_t largestBlock = getLargestFreeBlock(allocatedBlocks);
        if ( largestBlock == 0 ) break;
        printf ("allocated block of %I64d bytes\n", largestBlock);
        allocatedTotal += largestBlock;
    } while (true);
    printf ("---------------------------------\n");
    printf ("allocated a total of %I64d bytes\n", allocatedTotal);
    for ( int i = 0; i < allocatedBlocks.size(); i++ )
        cudaFree (allocatedBlocks[i]);
int main()
    cudaDeviceReset();
    void* buffer1;
    cudaMalloc(&buffer1, (size_t)2*1024*1024*1024+87320576);
    printFreeCudaMem();
    void* buffer2;
    cudaMalloc(&buffer2, 8192);
    printFreeCudaMem();
    return 0;
On my system, I get the following output:
Checking memory:
allocated block of 1903413248 bytes
allocated a total of 1903413248 bytes
Checking memory:
allocated block of 1902364672 bytes
allocated block of 16384 bytes
allocated block of 8192 bytes
allocated a total of 1903405056 bytes
Press any key to continue . . .
Any ideas what the reason is and how it can be avoided? Or is there a bug in printFreeCudaMem?
Bye,
Ingo
I fail to see how the output shown above is indicative of a “highly fragmented” memory. Could you clarify, please? What operating system is running on this platform?
Well, after allocating two blocks of memory of ~2.1GB and 8kb, I’d expect that the remaining free memory of ~1.9GB can be allocated as a whole, as it is possible before I allocate these 8kb. But afterwards, the remaining free memory can only be allocated in one huge block, an 64 small blocks.
The operating system is Windows 7 64bit.
Bye,
Ingo
