Memory handling. How we use large global memory of device.
I have just written a code that use a large amount of global memory in device. what i have written is given below:
I allocate large memory as char type array
                   char *chArray = 0;
             CUDA_SAFE_CALL( cudaMalloc((void**) &chArray , sizeof(int) *10000));
and using this as my need by typecasting it, as:
            int  *Int_array = (int*)chArray;
            double* Dou_array = (double*) &Int_array [500];
It is working fine.
But as we know type casting is a costly operations.
So, what is the efficient way to handle this problem.
Kundan
Typecasting is a compiler hint. It has no run-time component to it (unless u r dealing with some C++ may be…)
Why?
This works just as good and results in fewer headaches.
int *Int_Array = 0;
CUDA_SAFE_CALL( cudaMalloc((void**) &Int_Array , sizeof(int) *10000));
Regarding performance, Sarnath is right. There is no performance penalty. A type cast just tell the compiler how to deal with the array at compile time.
