Is there a way to get information about the memory interface of the current cuda device?
I have to compute the theoretical bandwidth, but I only have the clock rate
cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, 0);
... prop.clockRate ...
Thanks for your help.
avidday
2
I don’t think you can get that through the CUDA API. On Linux, the nvclock utility can get that information:
avid@quadro:~/plots/carbon-part$ nvclock -i
-- General info --
Card: nVidia Geforce 9500GT
Architecture: G96 A1
PCI id: 0x640
GPU clock: 594.000 MHz
Bustype: PCI-Express
-- Shader info --
Clock: 1512.000 MHz
Stream units: 32 (011b)
ROP units: 8 (b)
-- Memory info --
Amount: 512 MB
Type: 128 bit DDR3
Clock: 799.200 MHz
-- PCI-Express info --
Current Rate: 16X
Maximum rate: 16X
-- Sensor info --
Sensor: GPU Internal Sensor
GPU temperature: 56C
Fanspeed: 50.0%
-- VideoBios information --
Version: 62.94.35.00.00
Signon message: G96 P727 SKU 0001 VGA BIOS
Performance level 0: gpu 550MHz/shader 1400MHz/memory 800MHz/1.00V/100%
VID mask: 1
Voltage level 0: 0.95V, VID: 1
Voltage level 1: 1.00V, VID: 0
so there is definitely an API which can fetch the information at runtime, but not via CUDA.
Hm, If i would do this, I will be not longer operating system independent.
I think I will resign this feature.
Thanks for your answer.
Looks really nice. I will give it a try. But its only for windows platforms?
Yes, NVAPI is Windows-only at the moment. If you have an important application that could use NVAPI under Linux, please let us know.
I have :)
On a general note, what I would like also to do was to be able to write a linux script that monitors the GPUs in the system.
Such a simple script will have to enumerate through the gpus, get their busy/idle state, tempratures and mainly “real time” occupancy.
Something like a “top” utility for linux.
I know there is some functionality already available (such as tempratures, fan speed etc…) but i would like to have a tool that
can tell me how much of any 24 hours my GPU cluster has been working full speed.
thanks
eyal
avidday
8
I will second that. For us, the ability to extend our existing cluster monitoring and accounting solution to include the GPUs would be a big help.
