Memory Issues Having Trouble with Card Memory
So I’m relatively new at progrmming CUDA but am having some trouble with card memory. Basically, what I want to do is allocate memory on the card and then use this variable in a function. It all works perfect in emulation mode, but the variable isn’t what I set it to when I run it on the card. Here’s some code snippets:
global void indfitness(float *fitness)
int i = threadIdx.x;
fitness[i]= 5;
void mexFunction( int nlhs, mxArray *plhs,
int nrhs, mxArray *prhs)
float *fitness;
float *fitnessout_float;
//Allocate float array in shared memory for use on GPU
cudaMalloc((void**)&fitness, sizeof(float)*popSize);
// Kernel invocation
dim3 dimBlock(popSize);
indfitness<<<1, dimBlock>>>(fitness);
//Copy back to host
cudaMemcpy((void*)fitnessout_float, (void*)fitness, sizeof(float)*popSize, cudaMemcpyDeviceToHost);
Is there anything wrong with this?
Note: when I compile on the device, I get the warnings “Advisory: Cannot tell what pointer points to, assuming global memory space” but I don’t understant why it’s giving these to me.
bump! I’ve resorted to developing in emulation mode until I figure out why this is happening, because there are no problems if I don’t run on the card…
It seems to be correct, assuming that
  • popSize is an int and has been initialized to some positive value
  • memory for fitnessout_float has been alloc’d
The following code is working for me, when ran on the GPU. It is a minor variation of yours
Hope it helps,
[codebox]#include
fitness[i]= 5;
int main() {
float *fitness;
int popSize =10;
fitnessout_float = (float *)malloc(sizeof(float)*popSize);
//Copy back to host
for(int j = 0; j<popSize; j++)
cout << fitnessout_float[j] << " ";
[/codebox]
Thanks for the reply, but I’m still having trouble. Just for a small test, I wrote a small program (for use in matlab) that I attached here. It’s not at all working correctly; I don’t think it’s even running the kernel, because if I run in debug mode and put a print inside the kernel, it doesn’t print it even though it prints if I put a print before or after the kernel. Why would not not be even running the kernel, now?
Note that I’m also running on 64-bit Windows, but I’ve replaced the nvmexouts.bat, etc. with compatable verions for 64-bit, and so it compiles and runs, but just isn’t working correctly… Let me know if this does work for someone with 32-bit.
Thanks,
#include "mex.h"
#include "cutil.h"
void matrix_double2float( double *input_double, float *output_float,int N)
	int i;
	for (i = 0; i < N; i++) {
		output_float[i] = (float) input_double[i];
void matrix_float2double( float *input_float, double *output_double,int N)
	int i;
		output_double[i] = (double) input_float[i];
__global__ void indfitness(float *fitness)
	int ind = threadIdx.x;
	fitness[ind] = (float)ind;
void mexFunction( int nlhs, mxArray *plhs[],
				  int nrhs, mxArray *prhs[])
	float *fitness;
	double *fitnessout;
	int size = 10;
	int dims[] = {size};
	plhs[0] = mxCreateNumericArray(1, dims, mxDOUBLE_CLASS, mxREAL);
	//Get a pointer to the data space in our newly allocated memory
	fitnessout = mxGetPr(plhs[0]);
	cudaMalloc((void**)&fitness, sizeof(float)*size);
	//CUDA_SAFE_CALL(cudaMemset(fitness, 0.0, sizeof(float)*size));
	fitnessout_float = (float*)mxMalloc(sizeof(float)*size);
	dim3 dimBlock(size);
	//copy back
	cudaMemcpy((void*)fitnessout_float, (void*)fitness, sizeof(float)*size, cudaMemcpyDeviceToHost);
	mexPrintf("[%f]\n", fitnessout_float[1]);
	//copy into return array
	matrix_float2double(fitnessout_float, fitnessout, size);
“printf” would NOT even compile inside a kernel unless you are in emulation mode.
i.e.
If you are compiling for device, you cannot have "printf"s inside your kernel. It wont even compile
