Memory issues
So we had done the detection for images and videos it works.But when we use it for real time the memory gets full,even we have swap The memory as u can see in the image below,as soon it’s full ,we get the error as process killed.
Kindly Advise.
Thank you.
Hi there,
I think you will get better support if we move this post into the Jetson specific category. Interpreting the terminal output I think it is a Jetson TX1, so I will use that forum.
Detection usually runs on GPU which cannot access swap memory.
