Description
I used a sanitizer to analyze the memory usage of my app and discovered a memory leak occurring when invoking the createInferRuntime function. I have created a simple demo to replicate the memory leak. Could you please assist me in confirming whether I am using it incorrectly or if there is a bug present?
Environment
TensorRT Version: 8600
GPU Type: GTX-2080
Nvidia Driver Version: 510.47.03
CUDA Version: 11.6
CUDNN Version: 8.4.1
Operating System + Version: Ubuntu 18.04
Relevant Files
leak_test.cc
#include "NvInfer.h"
#include "NvInferRuntimeCommon.h"
#include <memory>
class Logger : public nvinfer1::ILogger {
public:
explicit Logger(Severity severity = Severity::kWARNING)
: reportable_severity(severity) {}
void log(Severity severity, const char *msg) noexcept override {}
Severity reportable_severity;
int main(int argc, char *argv[]) {
Logger logger;
auto runtime_ =
std::unique_ptr<nvinfer1::IRuntime>(nvinfer1::createInferRuntime(logger));
return 0;
CMakeLists.txt
cmake_minimum_required(VERSION 3.10)
project(leak_test)
set(CMAKE_CXX_FLAGS
"--std=c++17 -Wno-unused-variable -Wno-unused-function -Wno-unused-parameter -Wno-deprecated-declarations -g -fsanitize=address"
include_directories(/usr/include/x86_64-linux-gnu/)
include_directories(/usr/local/cuda/include/)
link_directories(/usr/lib/x86_64-linux-gnu/)
list(APPEND LIBRARIES nvinfer)
# Add the executable target
add_executable(leak_test leak_test.cc)
# Link against the required libraries
target_link_libraries(leak_test ${LIBRARIES})
Steps To Reproduce
mkdir build && cd buildcmake ..make./leak_test
Will report memory leak like this:
AddressSanitizer:DEADLYSIGNAL
==19489==ERROR: AddressSanitizer: SEGV on unknown address 0x000000000000 (pc 0x7f83585762cb bp 0x7ffe5e3a7a70 sp 0x7ffe5e3a7a50 T0)
==19489==The signal is caused by a READ memory access.
==19489==Hint: address points to the zero page.
#0 0x7f83585762cb in createInferRuntime_INTERNAL (/usr/lib/x86_64-linux-gnu/libnvinfer.so.8+0x142b2cb)
#1 0x55f8044cb0c1 in createInferRuntime /usr/include/x86_64-linux-gnu/NvInferRuntime.h:3653
#2 0x55f8044cb187 in main /usr/src/tensorrt/samples/leak_test/leak_test.cc:18
#3 0x7f83563b8c86 in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x21c86)
#4 0x55f8044cafe9 in _start (/usr/src/tensorrt/samples/leak_test/build/leak_test+0xfe9)
AddressSanitizer can not provide additional info.
SUMMARY: AddressSanitizer: SEGV (/usr/lib/x86_64-linux-gnu/libnvinfer.so.8+0x142b2cb) in createInferRuntime_INTERNAL
==19489==ABORTING
