Memory leak in TensorRT InstanceNormalization
I am converting a Pytorch model into onnx and then into trt for inference. My PyTorch model contains InstanceNormalization, whenever I replace InstanceNormalization to BatchNormalization then there is no memory leak.
When I iteratively inference the trt model containing InstanceNormalization then the GPU memory allocation increases at every iteration of inference.
When I use BatchNormalization, then there is no such effect of memory leaks.
Can you provide the following information so we can better help?
Provide details on the platforms you are using:
o Linux distro and version
o GPU type
o Nvidia driver version
o CUDA version
o CUDNN version
o Python version [if using python]
o Tensorflow and PyTorch version
o TensorRT version
Also, please share the scripts / model file to reproduce the issue.
  1. Please make a couple simple/dummy models containing just one or two layers, one with batchnorm and one with instancenorm ops that reproduce the issue rather than a larger complicated model.
  2. Please share the script you’re using to do inference on these models iteratively
The details are as follows:
Linux distro and version - Ubuntu 16.04
GPU type - RTX 2080Ti
Nvidia driver version - 435.21
CUDA version - 10.0
CUDNN version - 7.6.5
Python version [if using python] - 3.7.5
PyTorch version - Pytorch 1.3.1
TensorRT version - 7.0.0.11
The script and the model that you have asked for is uploaded and you can download it from the following link.
https://we.tl/t-hS8nE7RfXr
Sorry for the delayed response. I believe this was fixed in the opensource components here: https://github.com/NVIDIA/TensorRT/pull/315/files
You can build the OSS components on top of your TensorRT install following the instructions in the README here: https://github.com/NVIDIA/TensorRT
There’s an example script to automate this here: https://github.com/rmccorm4/tensorrt-utils/blob/master/OSS/build_OSS.sh
