GPU: RTX 2060 and also happens with RTX 2080 TI
• DeepStream Version
5.1
• TensorRT Version
I am using the devel docker image for deepstream-5.1
460
bugs
The issue can be reproduced with any config file containing smart-record configurations for 1 or more sources. The issue only happens with test5-app and doesn’t occur with deepstream-app.
Monitor the memory usage of the app PID or the docker container for a little while and observe the increase as shown in the figure below (taken from my experiment).
The following is the config file I used for this experiment.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
[tiled-display]
enable=1
rows=4
columns=5
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=4
uri=xxxxxxxxxxxxxxxxx
camera-id=0
rtsp-reconnect-interval-sec=5
gpu-id=0
cudadec-memtype=0
[source1]
enable=1
type=4
camera-id=1
gpu-id=0
cudadec-memtype=0
[source2]
enable=1
type=4
camera-id=2
gpu-id=0
cudadec-memtype=0
smart-record=2
smart-rec-dir-path=xxxxxxxxxxxxxxxxxxx
smart-rec-file-prefix=source2
smart-rec-video-cache=60
smart-rec-container=0
smart-rec-default-duration=10
smart-rec-start-time=5
smart-rec-duration=5
[source3]
enable=1
type=4
camera-id=3
gpu-id=0
cudadec-memtype=0
[source4]
enable=1
type=4
camera-id=4
gpu-id=0
cudadec-memtype=0
[source5]
enable=1
type=4
camera-id=5
gpu-id=0
cudadec-memtype=0
[source6]
enable=1
type=4
camera-id=6
gpu-id=0
cudadec-memtype=0
[source7]
enable=1
type=4
camera-id=7
gpu-id=0
cudadec-memtype=0
[source8]
enable=1
type=4
camera-id=8
gpu-id=0
cudadec-memtype=0
[source9]
enable=1
type=4
camera-id=9
gpu-id=0
cudadec-memtype=0
[source10]
enable=1
type=4
camera-id=10
gpu-id=0
cudadec-memtype=0
[source11]
enable=1
type=4
camera-id=11
gpu-id=0
cudadec-memtype=0
[source12]
enable=1
type=4
camera-id=12
gpu-id=0
cudadec-memtype=0
[source13]
enable=1
type=4
camera-id=13
gpu-id=0
cudadec-memtype=0
[source14]
enable=1
type=4
camera-id=14
gpu-id=0
cudadec-memtype=0
[source15]
enable=1
type=4
camera-id=15
gpu-id=0
cudadec-memtype=0
[source16]
enable=1
type=4
camera-id=16
gpu-id=0
cudadec-memtype=0
[source17]
enable=1
type=4
camera-id=17
gpu-id=0
cudadec-memtype=0
[source18]
enable=1
type=4
camera-id=18
gpu-id=0
cudadec-memtype=0
[source19]
enable=1
type=4
camera-id=19
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
type=2
sync=0
gpu-id=0
nvbuf-memory-type=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=8
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=1
clock-x-offset=1050
clock-y-offset=20
clock-text-size=18
clock-color=1;0;0;1
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=1
batch-size=20
batched-push-timeout=65000
width=1080
height=720
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
# Required to display the PGIE labels, should be added even when using config-file property
batch-size=20
# Required by the app for OSD, not a plugin property
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
gie-unique-id=1
nvbuf-memory-type=0
config-file=xxxxxxxxx
[tracker]
enable=1
tracker-width=640
tracker-height=384
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
ll-config-file=../configs/tracker_config.yml
gpu-id=0
enable-batch-process=1
[nvds-analytics]
enable=1
config-file=../configs/config_nvdsanalytics.txt
