Hi
This is my test code:
#include <opencv2/opencv.hpp>
#include <QDebug>
int main()
cv::VideoCapture camera(0);
if (!camera.isOpened()) {
qDebug() << "ERROR: Could not open camera";
return 1;
cv::namedWindow("Webcam");
cv::Mat frame;
while (1)
camera >> frame;
if (!frame.empty())
cv::imshow("Webcam", frame);
if (cv::waitKey(10) >= 0)
break;
camera.release();
return 0;
This is the test output log
ion@ion-desktop:~/build-testMemory-Desktop-Debug$ valgrind --leak-check=full --show-leak-kinds=all ./testMemory
==25655== Memcheck, a memory error detector
==25655== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
==25655== Using Valgrind-3.13.0 and LibVEX; rerun with -h for copyright info
==25655== Command: ./testMemory
==25655==
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (933) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
Gtk-Message: 14:30:44.812: Failed to load module "canberra-gtk-module"
==25655==
==25655== HEAP SUMMARY:
==25655== in use at exit: 4,439,680 bytes in 34,707 blocks
==25655== total heap usage: 83,816 allocs, 49,109 frees, 106,831,338 bytes allocated
==25655==
==25655== 59 bytes in 1 blocks are indirectly lost in loss record 1 of 15
==25655== at 0x4845BFC: malloc (in /usr/lib/valgrind/vgpreload_memcheck-arm64-linux.so)
==25655==
==25655== 128 bytes in 1 blocks are still reachable in loss record 2 of 15
==25655== at 0x48468F4: operator new[](unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-arm64-linux.so)
==25655==
==25655== 208 bytes in 13 blocks are possibly lost in loss record 3 of 15
==25655== at 0x4845B3C: malloc (in /usr/lib/valgrind/vgpreload_memcheck-arm64-linux.so)
==25655==
==25655== 1,872 bytes in 4 blocks are possibly lost in loss record 4 of 15
==25655== at 0x4847D10: realloc (in /usr/lib/valgrind/vgpreload_memcheck-arm64-linux.so)
==25655==
==25655== 1,948 bytes in 21 blocks are still reachable in loss record 5 of 15
==25655== at 0x484622C: operator new(unsigned long) (in /usr/lib/valgrind/vgpreload_memcheck-arm64-linux.so)
==25655==
==25655== 6,176 bytes in 193 blocks are still reachable in loss record 6 of 15
==25655== at 0x5BE14BC: g_closure_new_simple (in /usr/lib/aarch64-linux-gnu/libgobject-2.0.so.0.5600.4)
==25655==
==25655== 6,332 bytes in 50 blocks are possibly lost in loss record 7 of 15
==25655== at 0x4847B0C: calloc (in /usr/lib/valgrind/vgpreload_memcheck-arm64-linux.so)
==25655==
==25655== 7,952 bytes in 193 blocks are still reachable in loss record 8 of 15
==25655== at 0x5BE1474: g_closure_new_simple (in /usr/lib/aarch64-linux-gnu/libgobject-2.0.so.0.5600.4)
==25655==
==25655== 16,539 (16,480 direct, 59 indirect) bytes in 2 blocks are definitely lost in loss record 9 of 15
==25655==
==25655== 19,568 bytes in 753 blocks are still reachable in loss record 10 of 15
==25655== at 0x5C07DDC: g_type_create_instance (in /usr/lib/aarch64-linux-gnu/libgobject-2.0.so.0.5600.4)
==25655==
==25655== 38,788 bytes in 1,086 blocks are still reachable in loss record 11 of 15
==25655==
==25655== 160,008 bytes in 753 blocks are still reachable in loss record 12 of 15
==25655== at 0x5C07D94: g_type_create_instance (in /usr/lib/aarch64-linux-gnu/libgobject-2.0.so.0.5600.4)
==25655==
==25655== 241,637 bytes in 1,747 blocks are still reachable in loss record 13 of 15
==25655==
==25655== 1,593,370 bytes in 25,888 blocks are still reachable in loss record 14 of 15
==25655==
==25655== 2,137,858 bytes in 3,056 blocks are still reachable in loss record 15 of 15
==25655==
==25655== LEAK SUMMARY:
==25655== definitely lost: 16,480 bytes in 2 blocks
==25655== indirectly lost: 59 bytes in 1 blocks
==25655== possibly lost: 8,412 bytes in 67 blocks
==25655== still reachable: 4,207,433 bytes in 33,691 blocks
==25655== of which reachable via heuristic:
==25655== length64 : 7,264 bytes in 115 blocks
==25655== newarray : 2,144 bytes in 54 blocks
==25655== suppressed: 0 bytes in 0 blocks
==25655==
==25655== For counts of detected and suppressed errors, rerun with: -v
==25655== ERROR SUMMARY: 4 errors from 4 contexts (suppressed: 0 from 0)
How can I fix this issue?
