Hi, I am working with CUDA JIT compilation using nvrtc
and nvJitLink
. I am encountering a memory leak when calling the nvJitLinkAddData
/nvJitLinkAddFile
function during the linking process.
Here is my most simplified code:
#include <nvrtc.h>
#include <cuda.h>
#include <nvJitLink.h>
#include <nvrtc.h>
#include <iostream>
#define NVRTC_SAFE_CALL(x) \
do \
nvrtcResult result = x; \
if (result != NVRTC_SUCCESS) \
std::cerr << "\nerror: " #x " failed with error " \
<< nvrtcGetErrorString(result) << '\n'; \
exit(1); \
} while (0)
#define CUDA_SAFE_CALL(x) \
do \
CUresult result = x; \
if (result != CUDA_SUCCESS) \
const char *msg; \
cuGetErrorName(result, &msg); \
<< msg << '\n'; \
exit(1); \
} while (0)
#define NVJITLINK_SAFE_CALL(h, x) \
do \
nvJitLinkResult result = x; \
if (result != NVJITLINK_SUCCESS) \
<< result << '\n'; \
size_t lsize; \
result = nvJitLinkGetErrorLogSize(h, &lsize); \
if (result == NVJITLINK_SUCCESS && lsize > 0) \
char *log = (char *)malloc(lsize); \
result = nvJitLinkGetErrorLog(h, log); \
if (result == NVJITLINK_SUCCESS) \
std::cerr << "error: " << log << '\n'; \
free(log); \
exit(1); \
} while (0)
int main()
std::string program_name = "my_program";
std::string program_source = R"(
template <typename T>
__global__ void my_kernel(T* data) { *data = T{7}; }
for (int i = 0; i < 80000; i++)
nvrtcProgram prog;
NVRTC_SAFE_CALL(
nvrtcCreateProgram(&prog, // prog
program_source.c_str(), // buffer
program_name.c_str(), // name
0, // numHeaders
NULL, // headers
NULL)); // includeNames
nvrtcResult compileResult = nvrtcCompileProgram(prog, // prog
0, // numOptions
NULL); // options
// Obtain compilation log from the program.
if (compileResult != NVRTC_SUCCESS)
exit(1);
nvJitLinkHandle handle;
const char *lopts[] = {"-arch=sm_80"};
NVJITLINK_SAFE_CALL(handle, nvJitLinkCreate(&handle, 1, lopts));
NVJITLINK_SAFE_CALL(handle, nvJitLinkAddFile(handle, NVJITLINK_INPUT_OBJECT,
"/path/to/anyobject.o"));
NVJITLINK_SAFE_CALL(handle, nvJitLinkComplete(handle));
NVJITLINK_SAFE_CALL(handle, nvJitLinkUnload(handle));
NVJITLINK_SAFE_CALL(handle, nvJitLinkDestroy(&handle));
NVRTC_SAFE_CALL(nvrtcDestroyProgram(&prog));
// printf("i: %d\n", i);
The issue is that when I call nvJitLinkAddFile
, the memory usage continuously increases, and a memory leak occurs. However, when I comment out the line:
// NVJITLINK_SAFE_CALL(handle, nvJitLinkAddFile(handle, NVJITLINK_INPUT_OBJECT, "/path/to/anyobject.o"));
The memory leak stops, and the program runs as expected.
Compilation and Execution
I compile and run the code using the following command:
nvcc -std=c++14 ./main.cc -lnvrtc -lnvJitLink -ldl && ./a.out
Has anyone encountered similar memory leaks with nvJitLinkAddFile
? I’ve simplified the code as much as possible, but the issue persists. Any help or insights would be greatly appreciated!
Thank you in advance!
