Memory leak with USD Composer template
My team is encountering very high memory usage with the USD Composer app template whilst rendering frames for an extended period of time via Movie Capture.
Here is a log file showing the RAM usage of the Kit process over time:
Summary
2024-11-26 14:21:17 | INFO | kit (26556): 7.7 GiB
2024-11-26 14:31:27 | INFO | kit (26556): 7.8 GiB
2024-11-26 14:41:36 | INFO | kit (26556): 7.9 GiB
2024-11-26 14:51:46 | INFO | kit (26556): 8 GiB
2024-11-26 15:01:56 | INFO | kit (26556): 8 GiB
2024-11-26 15:12:06 | INFO | kit (26556): 8.1 GiB
2024-11-26 15:22:15 | INFO | kit (26556): 8.2 GiB
2024-11-26 15:32:25 | INFO | kit (26556): 8.3 GiB
2024-11-26 15:42:35 | INFO | kit (26556): 8.4 GiB
2024-11-26 15:52:45 | INFO | kit (26556): 8.5 GiB
2024-11-26 16:02:54 | INFO | kit (26556): 8.5 GiB
2024-11-26 16:13:04 | INFO | kit (26556): 8.6 GiB
2024-11-26 16:23:14 | INFO | kit (26556): 8.7 GiB
2024-11-26 16:33:23 | INFO | kit (26556): 8.8 GiB
2024-11-26 16:43:33 | INFO | kit (26556): 8.9 GiB
2024-11-26 16:53:43 | INFO | kit (26556): 9 GiB
2024-11-26 17:03:53 | INFO | kit (26556): 9.1 GiB
2024-11-26 17:14:04 | INFO | kit (26556): 9.1 GiB
2024-11-26 17:24:14 | INFO | kit (26556): 9.2 GiB
2024-11-26 17:34:23 | INFO | kit (26556): 9.3 GiB
2024-11-26 17:44:33 | INFO | kit (26556): 9.3 GiB
2024-11-26 17:54:43 | INFO | kit (26556): 9.4 GiB
2024-11-26 18:04:53 | INFO | kit (26556): 9.5 GiB
2024-11-26 18:15:02 | INFO | kit (26556): 9.6 GiB
2024-11-26 18:25:12 | INFO | kit (26556): 9.6 GiB
2024-11-26 18:35:22 | INFO | kit (26556): 9.7 GiB
2024-11-26 18:45:32 | INFO | kit (26556): 9.8 GiB
2024-11-26 18:55:41 | INFO | kit (26556): 9.8 GiB
2024-11-26 19:05:51 | INFO | kit (26556): 9.9 GiB
2024-11-26 19:16:01 | INFO | kit (26556): 10 GiB
2024-11-26 19:26:10 | INFO | kit (26556): 10.2 GiB
2024-11-26 19:36:20 | INFO | kit (26556): 10.2 GiB
2024-11-26 19:46:30 | INFO | kit (26556): 10.3 GiB
2024-11-26 19:56:40 | INFO | kit (26556): 10.4 GiB
2024-11-26 20:06:49 | INFO | kit (26556): 10.4 GiB
2024-11-26 20:16:59 | INFO | kit (26556): 10.5 GiB
2024-11-26 20:27:09 | INFO | kit (26556): 10.6 GiB
2024-11-26 20:37:18 | INFO | kit (26556): 10.7 GiB
2024-11-26 20:47:28 | INFO | kit (26556): 10.7 GiB
2024-11-26 20:57:38 | INFO | kit (26556): 10.8 GiB
2024-11-26 21:07:48 | INFO | kit (26556): 10.9 GiB
2024-11-26 21:17:57 | INFO | kit (26556): 10.9 GiB
2024-11-26 21:28:07 | INFO | kit (26556): 11 GiB
2024-11-26 21:38:17 | INFO | kit (26556): 11.1 GiB
2024-11-26 21:48:27 | INFO | kit (26556): 11.1 GiB
2024-11-26 21:58:36 | INFO | kit (26556): 11.2 GiB
2024-11-26 22:08:46 | INFO | kit (26556): 11.3 GiB
2024-11-26 22:18:56 | INFO | kit (26556): 11.3 GiB
2024-11-26 22:29:05 | INFO | kit (26556): 11.4 GiB
2024-11-26 22:39:15 | INFO | kit (26556): 11.5 GiB
2024-11-26 22:49:25 | INFO | kit (26556): 11.5 GiB
2024-11-26 22:59:35 | INFO | kit (26556): 11.6 GiB
2024-11-26 23:09:44 | INFO | kit (26556): 11.7 GiB
2024-11-26 23:19:54 | INFO | kit (26556): 11.7 GiB
2024-11-26 23:30:04 | INFO | kit (26556): 11.8 GiB
2024-11-26 23:40:14 | INFO | kit (26556): 11.9 GiB
2024-11-26 23:50:23 | INFO | kit (26556): 11.9 GiB
2024-11-27 00:00:33 | INFO | kit (26556): 12 GiB
2024-11-27 00:10:43 | INFO | kit (26556): 12.1 GiB
2024-11-27 00:20:52 | INFO | kit (26556): 13.1 GiB
2024-11-27 00:31:02 | INFO | kit (26556): 15.4 GiB
2024-11-27 00:41:12 | INFO | kit (26556): 17.6 GiB
2024-11-27 00:51:22 | INFO | kit (26556): 19.9 GiB
2024-11-27 01:01:31 | INFO | kit (26556): 22.6 GiB
2024-11-27 01:11:41 | INFO | kit (26556): 24.8 GiB
2024-11-27 01:21:51 | INFO | kit (26556): 27 GiB
2024-11-27 01:32:01 | INFO | kit (26556): 29.4 GiB
2024-11-27 01:42:10 | INFO | kit (26556): 31.6 GiB
2024-11-27 01:52:20 | INFO | kit (26556): 33.8 GiB
2024-11-27 02:02:30 | INFO | kit (26556): 36.1 GiB
2024-11-27 02:12:39 | INFO | kit (26556): 38.3 GiB
2024-11-27 02:22:49 | INFO | kit (26556): 40.5 GiB
2024-11-27 02:32:59 | INFO | kit (26556): 43.7 GiB
2024-11-27 02:43:09 | INFO | kit (26556): 45.9 GiB
2024-11-27 02:53:18 | INFO | kit (26556): 48.4 GiB
2024-11-27 03:03:28 | INFO | kit (26556): 50.4 GiB
2024-11-27 03:13:38 | INFO | kit (26556): 52.3 GiB
As you can see, after 13 hours of rendering, Kit has single-handedly filled the RAM, at which point Windows probably started killing random processes. This is not ideal, we’d very much like the ability to render overnight.
System specs:
Windows 10 Enterprise
i9-14900K
RTX 4090
64GB RAM
We’ve encountered the issue with the USD Composer app template with Kit 106.4 but as far as we can tell, it also happened with versions as far back as 106.2, so not a new bug with the latest releases.
Kind regards
Hey @axel.cocat
I appreciate the feedback! Ill make sure devs are aware of this
Thanks for letting us know. This looks like a memory leak with either the Movie Capture extension itself, or USD Composer. We will investigate.
I have filed a JIRA dev ticket to investigate. Could you provide us with the USD scene and some console logs on a second run to demonstrate the leak?
Just one question. You said RAM… do you mean VRAM or normal system RAM ?
Hi Ash and Richard, thanks for getting back to me.
Apologies for the delay, we’ve been trying to pinpoint the source of the leak. It turns out the issue also happens with a default empty scene without even running the movie capture. What we can tell so far is that the memory usage seems stable until we start using the UI : opening additional windows, changing the render settings, etc.
As far as we can tell this unfortunately looks like it’s coming from the UI system as a whole.
Yes Richard, I do mean normal RAM, not VRAM.
I will try this again on Kit 106.5 after the holiday break and report back.
I can provide a PAK ID if it helps get the ball rolling internally for you guys.
Kind regards,
Axel
Thanks. Yes please try 106.5. We have recently identified a memory leak with Kit 106 as we have fixed it. It may be related to this and we will try to get more details.
