i’m using an Jetson AGX Xavier and want to use the NVDLA and GPU for inference.
I’m unsure of the SOC memory management.
- Does the NVDLA and GPU have a unified shared memory?
- Can data be passed from GPU to NVDLA without any copies and vice versa?
DLA has it’s own SRAM.
But the data transfer between GPU <-> DLA is handled by an internal driver.
You will only need to prepare a GPU buffer for TensorRT as input.
Thanks for your reply.
Could you please provide me any sample code?
You can check following for the DLA sample:
