First time poster, but here goes.
I can’t seem to find out how to do mallocs, frees, and memcpys from device to device.
__device__ unsigned short int modMP(unsigned long int * x, unsigned long int sizeL, unsigned short int p)
unsigned long int size = sizeL * mp_bits_per_limb;
unsigned long int * x2_Original;
unsigned long int * x2;
cudaMalloc( (void **) &x2, size);
x2_Original = x2;
cudaMemcpy( x2, x, size, cudaMemcpyDeviceToDevice );
memcpy(x2, x, size);
unsigned long int * limit = x2 - 32 + size;
while(x2 <= limit)
*x2 = *x2 % p;
x2 += 16;
unsigned short int r = *((unsigned short int *)(x2-16));
cudaFree(x2_Original);
return r;
x is a pointer to the data of a gmp integer, while sizeL is how many limbs that integer has. As you can see I need to create a copy of x called x2 which I will then use to compute the mod. I have tested this function on host and it works. The error I get is that it does not like that I’m calling cudaMalloc, cudaFree and cudaMemcpy from the device. So I was wondering if there were functions that works on the device that accomplish the same goal.
Thanks in advance…
