Trying to load a detector network in DL Designer causes insanely high ram usage. There needs to be some cache limiting because I ran out of memory on a system with 64 gigs of RAM trying to load a single object detector ONNX file.
Hi, sorry for your trouble. To help us better understand and investigate the problem, could you share more details?
- What is your system, Windows, Linux, or L4T?
- In what circumstance did the memory overrun happen? loading a model, editing a model, profiling a model (with which profiler)?
- Is it possible for you to share with us your model to reproduce the problem? If not, can you tell us more about the model itself?
Gaoyan Xie
Hey,
Thanks for the quick reply.
I’m on Windows 11.
The memory overrun happens if I try to load an onnx model into the DL Designer app by dragging the file into the window. The ambient memory before triggering hovers at around ~8 GB and then shoots up to 64+ and crashes when trying to load the model.
It is a MMRotate based detector model. However, I probably cannot share the model as is, as it has proprietary elements. However, I will have a talk with the team to see how much I can divulge and get back to you. Would any other information be helpful?
Thanks, our engineering team is actively investigating this problem.
Gaoyan Xie
This problem has been fixed in our latest release (2025.1): Nsight Deep Learning Designer - Get Started | NVIDIA Developer
Please give it a try and let us know if the problem is resolved on your end.
Thanks,
Gaoyan Xie
Hey, yes it is fixed now. The overrun is no longer present for the same action.
