When I run the Compute Visual Profiler, instead of a call to one of my kernels show this “memset32_aligned1d” method.
All I could find is that it is a memory alignment function used internally by CUDA, but why is it calling this instead of my kernel?
Are you calling cudaMemset(…) in your code?
Actually when I use cudaMemset inside the kernel I get this error: “calling a host function(“cudaMemset”) from a device/global function(“function”) is not allowed”, but when I use the C memset it works just fine.
And even if I comment the memset, I still have this memset32_aligned1D showing in the Compute Visual Profiler.
cudaMemset is a host function. You can’t call it from a kernel.
It looks like you are running the wrong binary in your profiler. If you uncomment all GPU calls in the application, do you still have a memset32_aligned1D call in CVP?
Perhaps the application was compiled in cuda 3.2 emulation mode ?
Inside the kernel I´m using just memset, not cudaMemset. I had tested it in other kernels and it seems to work.
I check the binary I was running and it´s the right one.
If I uncomment all GPU calls I still hava a memset32_aligned1D call.
I tried using a for loop in the place of the memset, but no changes in the CVP.
But now I tried commenting the kernels calls. In the CVP the kernels calls are gone, so I know it´s the right binary I´m running.
There is just cudaMallocs,cudaMemcpys, and cudaFrees in the code, and still the memset32_aligned1D is there.
In the Profiler Output tab, shows that the memset32_aligned1D is the first method to be called, the GPU Timestamp is 0.
I´m compiling it in cuda 4.0 debug mode.
