I have recently bought jetson agx orin 64gb. The built-in storage is not sufficient for me. what is the best approach to merge my SD(128 GB) storage with jetson. The required solution is for jetson to use the external SD card which i dont intend to remove once i put it in
Is that the devkit from NVIDIA or custom board?
Please refer to the following instruction to setup SD as external device for rootfs.
Flashing Support — Flashing to an External Storage Device
You could also use NVMe SSD as another option.
