I want to merge two RT graphs into a single graph. But while merging I’m getting error.
My code is as follows:
import tensorflow as tf
from tensorflow.python.compiler.tensorrt import trt_convert as trt
saved_model1 = "/home/xavier2/saved_model/ssd_tomato_l1"
saved_model2 = "/home/xavier2/saved_model/faster_rcnn_tomato_l2_grid_750x750"
def create_trt_inference_graph(graph_path):
converter = trt.TrtGraphConverter(input_saved_model_dir=graph_path ,
precision_mode=trt.TrtPrecisionMode.FP16)
converted_graph_def = converter.convert()
return converted_graph_def
def get_serialized_graph(graph_path):
converted_graph_def = create_trt_inference_graph(graph_path)
serial_def = converted_graph_def.SerializeToString()
return serial_def
def get_frozen_graph(graph_path):
graph_def = tf.GraphDef()
graph_def.ParseFromString(get_serialized_graph(graph_path))
return graph_def
def rename_frame_name(graphdef, suffix):
# Bug reported at https://github.com/tensorflow/tensorflow/issues/22162#issuecomment-428091121
for n in graphdef.node:
if "while" in n.name:
if "frame_name" in n.attr:
n.attr["frame_name"].s = str(n.attr["frame_name"]).replace("while_context","while_context" + suffix).encode('utf-8')
l1_graph = tf.Graph()
with l1_graph.as_default():
trt_graph1 = get_frozen_graph(saved_model1)
[tf_input1, tf_scores1, tf_boxes1, tf_classes1, tf_num_detections1] = tf.import_graph_def(trt_graph1,
return_elements=['import/image_tensor:0', 'import/detection_scores:0', 'import/detection_boxes:0', 'import/detection_classes:0','import/num_detections:0'])
connected_graph = tf.Graph()
with connected_graph.as_default():
l1_graph_def = l1_graph.as_graph_def()
g1name = 'ved'
rename_frame_name(l1_graph_def, g1name)
tf.import_graph_def(l1_graph_def, name=g1name)
trt_graph2 = get_frozen_graph(saved_model2)
g2name = 'level2'
rename_frame_name(trt_graph2, g2name)
[tf_scores, tf_boxes, tf_classes, tf_num_detections] = tf.import_graph_def(trt_graph2,
return_elements=['import/detection_scores:0', 'import/detection_boxes:0', 'import/detection_classes:0','import/num_detections:0'])
It throws following error:
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/importer.py", line 427, in import_graph_def
graph._c_graph, serialized, options) # pylint: disable=protected-access
tensorflow.python.framework.errors_impl.InvalidArgumentError: Cannot add function 'TRTEngineOp_1_native_segment' because a different function with the same name already exists.
During handling of the above exception, another exception occurred:
File "<stdin>", line 10, in <module>
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/util/deprecation.py", line 507, in new_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/importer.py", line 431, in import_graph_def
raise ValueError(str(e))
ValueError: Cannot add function 'TRTEngineOp_1_native_segment' because a different function with the same name already exists.
My specs are:
Tensorflow: 1.14.0
Python: 3.6.8
Platform: NVIDIA Jetson AGX Xavier Ubuntu 18.04.2 LTS (GNU/Linux 4.9.140-tegra aarch64)
