I am trying to modify the MersenneTwister example in the SDK and use it in my own program. I found that the example in the original form works fine.
However, if I change the number of points to generate, say to 24000, then it doesn’t generate uniformly random numbers.
Please check the pictures. The first one has PATH_N = 24000000, the second one has PATH_N = 24000. You can see there is big difference.
How to fix this? Thanks.
Bo
