My current model is a custom model that detects persons, faces, furniture, and classify body actions. Nvinferserver tensor output gives me all the outputs fine.
From now on, I need to add a second model to classify emotions from faces crops.
At first I was intented to get face bboxes from tensors, image from gstbuffer and crop faces to add them to metadata so my second model work on faces only.
But, after an exhaustive search I haven’t found a way to operate on nvinferserver tensor output and send faces in metada using NVDS_CROP_IMAGE_META using python only.
I’m working on DS6.3.
Any help will be greatly appreciated.
Thanks in advance
I think the cropping is unnecessary. You can add a secondary gie and set its process_mode to PROCESS_MODE_CLIP_OBJECTS. Then set operate_on_class_ids to the value of the face class.
Just like:
pgie (detects faces) --> sgie(classify)
You can refer deepstream-test2, it is one pgie(detection) with three sgies(classification).
• DeepStream Version
• TensorRT Version
• The pipeline being used
Morning @junshengy,
Let me send you my model configs for PGIE and SGIE where you’ll see that my first model’s output doesn’t adhere to deepstream’s DeepStream SDK API Reference.
Can you help me to figure out how the PGIE model output should be for the SGIE to be able to infer on faces only despite it will receive 14 other outputs from PGIE?
With that piece of information I can manage to get the pipeline up and running. PGIE.config.pbtxt.txt (1.9 KB) SGIE.config.pbtxt.txt (943 Bytes)
Oh! I forgot to say that after SGIE, I also need the 14 remaining outputs from the PGIE to be included in the tensors. At this point I’m assuming it will be available as metadata…
These configuration files are useless, please refer to /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test2 and the link above first.
I can make my first model to output classIds, scores and nms , but I don’t figure how tensors should be for the SGIE to operate on faces smoothly given that my first model has outputs of type detector, classifier and keypoints.
Hi @junshengy
1 what format/structure classids and the bboxes should have given my actual output tensors from PGIE: PGIE.config.pbtxt.txt ?
2 deepstream-ssd-parser uses python (my mistake)
3 Given classids + bboxes tensor + SGIE with PROCESS_MODE_CLIP_OBJECTS will my SGIE operate on face crops only? Where does the cropping takes place PGIE or SGIE?
4. Do I need to add metadata of type NVDS_CROP_IMAGE_META?
It depends on your model, I guess it should be face_bboxes.
sgie will clip based on the bbox in the object meta, and the clip happens inside nvinferserver.
nvinferserver is open sources. refer bool GstNvInferServerImpl::shouldInferObject at /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvinferserver/gstnvinferserver_impl.cpp
