Please don’t disable EQOS in UEFI since it may cause MGBE failed to work.
You can replace <Linux_for_Tegra>/bootloader/uefi_jetson.bin with uefi_Jetson_DEBUG.bin you built w/o any change in UEFI source and share the full log for further check.
I have replaced uefi_Jetson_Debug.bin, and the log is the same as the problem link I shared above.
After using MGBE, UEFI startup gets stuck at the same location.
Turning off MGBE does not cause it to get stuck. uefi.txt (147.3 KB)
Switch case requires to discuss with switch vendor. It looks like the device tree is correct to me but we are uncertain if any missing for a switch case.
Since I see that the network in UEFI is not currently enabled, do you mean that I can enable the UEFI network function by modifying the parameters in the device tree?
