如接入10G设备,有影响吗?如接入1000M设备有影响吗?
kayccc
3
暂时没有使用9000,对于1000M设备,使用还是英伟达默认配置
Related topics
| 英伟达团队您好,在R39 (release), REVISION: 2.0上开启mgbe2_0 mtu巨型帧不会报错,但在R38 (release), REVISION: 4.0上有报错? | 2 | 160 | August 10, 2026 | |
| 使用两个NV devkit板子的mgbe2_0接口对测,iperf3速率未达到预期(预期9.4Gbits/sec以上),如何继续提高? | 9 | 395 | March 2, 2026 | |
| Set MTU of MGBE0 | 13 | 573 | February 3, 2025 | |
| 两个板卡对测mgbe2_0的10G速率 | 3 | 283 | March 25, 2026 | |
| Jeston t5000 100G 网络带宽不达标 (Linux 39.2版本) | 1 | 158 | June 24, 2026 | |
| How to set the MTU of mgbe1_0 to 9000? | 3 | 964 | April 17, 2023 | |
| 英伟达团队,您好,请教一个问题,mgbe0_0和mgbe1_0是资源共享的吗 | 4 | 177 | May 22, 2026 | |
| AGX Thor QSFP MGBE Link Instability Between Two DevKits | 3 | 311 | March 29, 2026 | |
| The information of MBGE on our customized carrier board is different from dev-kit | 14 | 521 | November 6, 2025 | |
| Jetson AGX Thor MGBE: TX packet flood (~200k pkt/s) with UDP frames larger than 1500 bytes (USRP X310 / UHD) | 7 | 105 | November 9, 2026 |
