Hello, our customer requires two orins to connect through MGBE, can this part be directly connected? Any points to note?
There is no special note required here. Do you hit any problem?
Hello, my side of the project is ready to use the double orin scheme, currently I want to use the MGBM piece for direct linking. But I didn’t get an actual answer after referring to DG. So I want to confirm whether you can use MGBE to directly interconnect the dual orin. If so, is there anything to be aware of?
What kind of function would you want to test? Have you evaluate that on devkit?
If devkit can work then your own usecase/custom board shall work too.
