I am having a problem with using the micro-usb port on the Tx2.
First whenever I try to connect a peripheral device to the micro-usb port by using a micro-usb to female Usb adapter, then connecting to the device, the device does not connect. When checking dmesg on the tx2 the output is:
[ 130.584829] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
[ 130.604852] extcon-gpio-states external-connection:extcon@1: Cable state:1, cable id:2
(When the adapter is connected)
[ 140.337386] usb 1-1: new full-speed USB device number 10 using tegra-xusb
[ 140.338099] usb 1-1: Device not responding to setup address.
[ 140.550082] usb 1-1: Device not responding to setup address.
[ 140.761402] usb 1-1: device not accepting address 10, error -71
[ 140.885436] usb 1-1: new full-speed USB device number 11 using tegra-xusb
[ 140.886126] usb 1-1: Device not responding to setup address.
[ 141.097947] usb 1-1: Device not responding to setup address.
[ 141.309508] usb 1-1: device not accepting address 11, error -71
[ 141.315802] usb usb1-port1: attempt power cycle
(When a peripheral device is connected)
I dealt with this temporarily by connecting a usb hub to the usb port. Now I need to enter the Jetson Tx2 into recovery mode, needing to be connected to a host machine using the micro-usb cable included with the Tx2.
I first tried using a virtual machine with ubuntu 16.04 installed. When the Tx2 was connected and in recovery mode it was not available as a USB device for the vm. When checking device manager on windows, the connection using the cable is detected but the Tx2 connected is shown as:
“Unknown USB Device (Device Descriptor Request Failed)”
Finally I attempted to connect the tx2 (in recovery mode) in the same way to a full Ubuntu machine running Ubuntu 20.04. lsusb does not show any connection with the Tx2. Using dmesg the output given when connecting the Tx2 is:
[ 417.564793] usb 1-1: new full-speed USB device number 28 using xhci_hcd
[ 417.692769] usb 1-1: device descriptor read/64, error -71
[ 417.929242] usb 1-1: device descriptor read/64, error -71
[ 418.165064] usb 1-1: new full-speed USB device number 29 using xhci_hcd
[ 418.293161] usb 1-1: device descriptor read/64, error -71
[ 418.529104] usb 1-1: device descriptor read/64, error -71
[ 418.637213] usb usb1-port1: attempt power cycle
[ 419.289055] usb 1-1: new full-speed USB device number 30 using xhci_hcd
[ 419.289278] usb 1-1: Device not responding to setup address.
[ 419.497217] usb 1-1: Device not responding to setup address.
[ 419.705089] usb 1-1: device not accepting address 30, error -71
[ 419.833059] usb 1-1: new full-speed USB device number 31 using xhci_hcd
[ 419.833274] usb 1-1: Device not responding to setup address.
[ 420.041366] usb 1-1: Device not responding to setup address.
[ 420.249190] usb 1-1: device not accepting address 31, error -71
[ 420.249338] usb usb1-port1: unable to enumerate USB device
Could this be a hardware issue on the Tx2 itself? I would appreciate any help that you can offer.
Thank you.
