MicroSD card not working in Xavier NX A203 model
Hi, I’m trying MicroSD card socket with 2 different card but not working or seeing. How can i fix that. Is this a hardware problem ? If this is a hardware problem how can i learn that problem ?
Thanks for helping.
It is not hardware problem. You misunderstood the situation.
Please refer to this post from Jetson Nano forum. The idea is similar. Just your case is A203 custom board.
I’m really beginner level on this situation. Can you explain in a little more detail what exactly I should do?
Go to the board vendor’s website and search for the BSP they provided for this board.
If you are not using NV Devkit then official NV BSP can’t run on your board with correct behavior.
If I do the steps in the video, will the micro SD slot work? BSP installation is very expensive I’m student.
I don’t know what video you are talking about. Please post it.
