I have followed the steps mentioned below to build the samples provided under the vision works folder.
- Copied the Samples folder to writeable location
- Edited the nmake file as follows
Dependency locations
CUDA_DIR = C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v8.0
OPENCV_DIR = C:\Library\Opencv\opencv\build
OPENCV_VERSION = 2413
VISIONWORKS_DIR = C:\Program Files\NVIDIA VisionWorks
Debug build?
dbg = 2
- Opened the Developer Command Prompt for VS2015
- Ran the nmake command
I face the following issues
obj\debug\main_feature_tracker.obj : fatal error LNK1112: module machine type ‘X86’ conflicts with target machine type ‘x64’
NMAKE : fatal error U1077: ‘“C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\BIN\cl.EXE”’ : return code ‘0x2’
Stop.
on running dumpbin.exe on the generated .lib file, I observe that they are x86.
Also I observe that the DLLs for opencv are getting copied from C:\Library\Opencv\opencv\build\x64\vc12\bin\opencv_nonfree2413d.dll
VC12 (VS2013) versions
But i would like it to get built against vc14 libraries
Requesting you to please suggest ways to overcome these 2 issues
Regards
Ajay
