I have an IR camera using MIPI CSI 2 interface without I2C communication. It streams data with static configuration, if only it has power on.
Params:
- width: 640
- height: 480
- framerate: 50
- color format: UYVY
- pixel bit depth: 16
Due to poor documentation other stream parameters are unknown.
I have already working driver on Xavier NX with JetPack 5.1.2. The driver was made based on nv_imx219 driver with just comment out calling functions for I2C communication and reporting no errors with this communication. I have also changed first mode in driver tables and device tree for parameter above. On Xavier the driver always is initialized with no errors even though the camera is unplugged. It streams video properly when gets data and sends green screen otherwise.
I am trying to migrate this driver (and also device tree) to Orin NX with JetPack 6.1, but it doesn’t work - always streams green screen. Debug logs are the same no matter if the camera are plugged or not. Initialization logs are the same as on Xavier.
v4l2-ctl -d /dev/video1 --stream-mmap --stream-count=100 --verbose
VIDIOC_QUERYCAP: ok
VIDIOC_REQBUFS returned 0 (Success)
VIDIOC_QUERYBUF returned 0 (Success)
VIDIOC_QBUF returned 0 (Success)
VIDIOC_STREAMON returned 0 (Success)
cap dqbuf: 0 seq: 0 bytesused: 614400 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq: 1 bytesused: 614400 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq: 2 bytesused: 614400 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
cap dqbuf: 3 seq: 3 bytesused: 614400 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
^C
cat /sys/kernel/debug/tracing/trace_pipe
<...>-2825 [005] ....... 319.273766: tegra_channel_open: vi-output, imx477 10-0010
v4l2-ctl-2825 [005] ....... 319.276975: tegra_channel_set_power: imx477 10-0010 : 0x1
v4l2-ctl-2825 [005] ....... 319.276985: camera_common_s_power: status : 0x1
v4l2-ctl-2825 [005] ....... 319.300114: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2825 [005] ....... 319.300119: csi_s_power: enable : 0x1
v4l2-ctl-2825 [005] ....... 319.301519: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [007] ....... 319.311501: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [007] ....... 319.311510: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [007] ....... 319.311511: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [007] ....... 319.311512: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
v4l2-ctl-2825 [005] ....... 319.311721: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-2825 [005] ....... 319.313906: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-2825 [005] ....... 319.313911: csi_s_stream: enable : 0x1
v4l2-ctl-2825 [007] ....... 319.314232: tegra_channel_set_stream: imx477 10-0010 : 0x1
vi-output, imx4-2827 [002] ....... 324.317710: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [004] ....... 324.317925: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [004] ....... 324.317940: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [004] ....... 324.317942: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [004] ....... 324.317945: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2827 [002] ....... 329.437175: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [004] ....... 329.437387: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [004] ....... 329.437399: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [004] ....... 329.437401: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [004] ....... 329.437402: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2827 [002] ....... 334.557177: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [004] ....... 334.557518: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [004] ....... 334.557533: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [004] ....... 334.557535: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [004] ....... 334.557536: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2827 [002] ....... 339.676739: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [006] ....... 339.677029: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 339.677044: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 339.677046: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 339.677047: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2827 [000] ....... 344.796604: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [006] ....... 344.796832: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 344.796847: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 344.796849: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 344.796850: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2827 [003] ....... 349.917004: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [006] ....... 349.917370: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 349.917384: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 349.917385: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 349.917387: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2827 [003] ....... 355.037138: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [006] ....... 355.037486: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 355.037499: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 355.037500: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [006] ....... 355.037502: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2827 [003] ....... 360.157087: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [003] ....... 360.157311: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [003] ....... 360.157325: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [003] ....... 360.157327: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [003] ....... 360.157329: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2827 [005] ....... 365.276767: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [000] ....... 365.276937: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [000] ....... 365.276969: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [000] ....... 365.276981: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [000] ....... 365.276983: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2827 [006] ....... 370.397810: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [000] ....... 370.398339: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [000] ....... 370.398361: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [000] ....... 370.398366: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [000] ....... 370.398368: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2827 [006] ....... 375.517010: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
vi-output, imx4-2826 [000] ....... 375.517247: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [000] ....... 375.517281: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [000] ....... 375.517292: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
vi-output, imx4-2826 [000] ....... 375.517296: vi_task_submit: class_id:48 ch:0 syncpt_id:36 syncpt_thresh:303
pid:2826 tid:2826
v4l2-ctl-2825 [001] ....... 377.530497: tegra_channel_close: vi-output, imx477 10-0010
vi-output, imx4-2827 [001] ....... 380.636912: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 13
v4l2-ctl-2825 [002] ....... 380.637249: tegra_channel_set_stream: enable : 0x0
v4l2-ctl-2825 [002] ....... 380.637257: tegra_channel_set_stream: imx477 10-0010 : 0x0
v4l2-ctl-2825 [002] ....... 380.688274: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-2825 [002] ....... 380.688279: csi_s_stream: enable : 0x0
v4l2-ctl-2825 [002] ....... 380.691715: tegra_channel_set_power: imx477 10-0010 : 0x0
v4l2-ctl-2825 [002] ....... 380.691829: camera_common_s_power: status : 0x0
v4l2-ctl-2825 [001] ....... 380.691862: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x0
v4l2-ctl-2825 [001] ....... 380.691867: csi_s_power: enable : 0x0
It cannot be the hardware problem because I use the same camera and all wires for both Xavier and Orin. CSI port on Orin is also good because it works with other camera with imx477 sensor.
Is there any new restrictions on Orin NX or JetPack 6.1 that not tolerate e.g. some wrong parameters in device tree? On Xavier NX parameters like clock frequency or line length was probably wrong, but it works despite that.
