We just got our MikroTik CRS804 switch, and attached 4x sparks - the fans are LOUD and spinning at max speed. The sparks are idle!
Should we tweak the fan curve? Or just replace them with 2x Noctua NF-A4x20 PWM fans?
Does anyone have similar issues? Thanks!
Tweak the fan configs in the Router OS they are way too aggressively set. I had Claude reset mine so much better.
I use the Mikrotik CRS504 for my sparks. What helped me a but was to install the 7.21.5 firmware. It got noticeably quieter.
Second on checking the configuration, the fans should not spin at max speed at all with only 4 clients that can at most use half of the switch’s maximum bandwidth, never mind when they aren’t using it at all. I actually have that same switch with 4 sparks connected and the only time I’ve heard the fans spin to maximum speed was when I tested its operation.
How many sparks are you using with CRS504?
Is speed of these 4 ports working good enough for 4 node models setup? which model you are running currently?
I‘m running GLM 5.2 inside hermes at around 25-26 tok/s depending on the task. See more details here: GLM 5.2 Hybrid-FP8+NVFP4+MXFP4 + Optimal runtime recipe - #23 by mike_ber
Do you know specifically what Claude did? I’m also using Claude, and it’s not able to make it work!
which cables are you using with this switch and the spark?
I don’t trust Claude, and now it’s telling me I need to buy:
AOC = Active Optical Cable. It’s a cable with the fiber-optic transceivers permanently built into both ends, so from the outside it looks and plugs in exactly like your current cables (QSFP56 on each end) — but internally it converts the electrical signal to light, sends it over a thin fiber, and converts it back at the other end.
These are apparently different from the cables I bought at microcenter…
Yeah sometimes Claude gets wonky on the networking for Sparks I point it at
and this was the other one I think I pointed mine at to ground it
@vgoklani Before changing the fan speeds I would recommend making sure your firmware is updated. That happened to me a few weeks ago and burned an entire afternoon figuring it out. As soon as I updated the firmware it fixed it and haven’t had a problem since.
Thanks for the reply! Yes Claude update both the firmware and the OS.
Claude is now blaming the cables, these are the official “nvidia” cables from microcenter…
Microcenter jacks up the price big time on there site and Amazon. I’ve had good luck with these:
Yes I love my NADDOD cables they are rock solid
