MiMo V2.5 Omni on 3x DGX Spark: TP=3 + MTP + 1M context 39 tok/s
Wanted to share a build that took some real work to land: running Xiaomi’s MiMo V2.5 (310B total / 15B active MoE, NVFP4) FULLY omnimodal (text, image, video, audio) at 1,000,000 token context across 3x DGX Spark over RoCE, no switch.
The challenge:
MiMo has 64 attention heads and 4 KV heads. Neither divides by 3, so stock vLLM cannot tensor-parallel shard it across 3 nodes (the QKV split asserts on exact divisibility). PP=3 works but kills MTP and tanks single-stream throughput.
The fix (virtual-head padding):
We pad the heads to 96 query / 6 KV so they divide cleanly by 3 (32 q / 2 KV per rank), then zero-mask the pad heads so they contribute nothing. This is the same approach used for MiniMax-M3’s TP=3, ported onto MiMo’s attention class AND the MTP draft config. Two more fixes were needed: a FusedMoE zero-fill (the uninitialized padded MoE tail was corrupting NVFP4 output until made truly zero-equivalent), and an attention_sink_bias padding fix for the MTP draft (the loader did 64//3=21 while the virtual sink pads to 32).
Results (69-scenario tool-calling eval, thinking OFF, 3-run avg):
- Quality 97.3, Responsiveness 96.4, Deployability 97.3
- Decode 38.8 tok/s, effective 35.1 tok/s
- Median answer latency ~1.2s
- KV cache 3,127,938 tokens at 1M context (3.13x concurrency)
- All 4 modalities verified live (described a real video clip + its audio track)
Thinking ON vs OFF (6 full runs): OFF wins clearly, 97.3 vs 88.9 quality and 2x lower answer latency. Thinking ON only posts higher raw tokens/sec because it generates internal reasoning tokens. For agentic / tool-calling work, run thinking OFF.
Infra notes: per-node HCA mapping for NCCL, Ray executor with object-store-memory capped to 1GB + memory-monitor disabled (the GB10 unified memory sits near full when loaded, which is normal), worker-first launch, MTU 9000.
Full recipe, the patch mod, and every raw benchmark JSON (reproducible):
Happy to answer questions on the virtual-head sharding or the RoCE setup. Curious if anyone has pushed context past 1M on the 3-node config.
Keep releasing these avesome tweaked models. My third Spark has arrived, I just need the cables to show up to take them all for a TP=3 spin.
So between this one and Minimax M3, which one is working better for you?
Minimax is too slow to do anything with I think I got the most 15 tok/s so I just gave up this literally gives us TP=3 and MTP and on par with DS4
Definitely looking forward to try this. Do you have a guide or similar explaining how to practically tweak models to work on non-power of two TPs?
Hi ;) can you tell us where did you get these mods?
  • ray-keep-node-nccl-hca
  • fix-prometheus-instrumentator-router
  • fix-mimo-v2-vllm
  • fix-modelopt-mixed-mxfp8
TAI
The core MiMo mods came from a3refaat’s MiMo V2.5 NVFP4 DGX Spark PR to eugr/spark-vllm-docker (#251), then we adapted/extended them for TP=3, Omni, MTP, and 1M context.
Credit chain should include: Xiaomi/MiMo, Luke Alonso’s NVFP4 export/build, a3refaat’s 2x Spark MiMo PR/mods, CyberTen/mclenithan as credited in that thread, vLLM contributors/PR #41797 for TRITON_ATTN_DIFFKV, and our local TP=3 virtual-head + Ray/NCCL glue.
Thanks ;) saying that it would be good to have all these info in the repo ;) cheers TAI
Now that’s proper setup!
These are all in the repo there’s a section called Credits. Cheers 👍
