MiMo V2.6 Pro RL on 8× DGX Spark: 17.8 → 68.3 tok/s with DFlash
I’ve published our eight-Spark MiMo V2.6 Pro RL setup using official weights, vLLM and DFlash.
Repository, setup and results⁠
Across four long structured-output tasks, throughput increased from 17.8 to 68.3 tokens/s, including prefill and request overhead. Both runs used the same patched runtime, with speculation enabled or disabled.
Answers matched byte for byte across 12 cases, including two baseline mistakes. We also tested four concurrent requests and a 257K-token input.
The repo includes patches, kernel source, pinned configuration and raw results. Interested in results from other Spark setups.
Working on the same optimization for dealign’s uncensored model now as well
This is really nice to see. So 68.3 tokens/s at C1? What was C4?
Thanks for sharing - this is excellent and shows the difference DFlash can make.
I got your recipe set up successfully here on 8 sparks, then tried a variant of it on SGLang rather than vLLM to see. Encouragingly, it added a bit more throughput (C1 at 93 toks/s). The follow-on tests are at:
A quick follow-up: TP8 now at 104.6 toks/s at C1 and 306.7 toks/s at C8 for the long structure extraction test. More on the updated github repo.
Awesome job again! These new models are looking so much more efficient. It’s really challenging the argument that Spark clusters are slow. I never thought I’d see numbers like these on Sparks. I’m going to test your DSV4.1F recipe first then this. I’m really hating my slow internet.
It’d be interesting if you could also do the benchmarks with thinking on.
Finally something to put 1kW out of my hardware!
