• Hardware Platform Jetsion AGX
• DeepStream Version 6.3
• JetPack Version R35 4.1
Using nvurisrcbin to connect to an RTSP stream, which then goes to nvstreammux->nvinfer->appsink, similar to deepstream-test3
When running I see the following errors at the start.
0:00:08.535052270 1404775 0xfffed002af00 ERROR GST_PADS gstpad.c:3352:gst_pad_query_latency_default:<uri-decode-bin:vsrc_0> minimum latency bigger than maximum latency
0:00:08.535645162 1404775 0xfffed002af00 ERROR GST_PADS gstpad.c:3352:gst_pad_query_latency_default:<source-bin-00:src> minimum latency bigger than maximum latency
0:00:08.535873717 1404775 0xfffed002af00 ERROR GST_PADS gstpad.c:3352:gst_pad_query_latency_default:<queue_element:src> minimum latency bigger than maximum latency
0:00:08.535916887 1404775 0xfffed002af00 ERROR GST_PADS gstpad.c:3352:gst_pad_query_latency_default:<stream-muxer:src> minimum latency bigger than maximum latency
This seems to want me to adjust the minimum or maximum latency values, but the only plugin that has a relevant property is nvstreammux-new, which seems to be only used if “sync-inputs is on”
What is the source of this error, and how do change my configuration to resolve it?
