• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.1.1
Docker container nvcr.io/nvidia/deepstream:6.1.1-samples
• TensorRT Version 8.4.1.5
• NVIDIA GPU Driver Version (valid for GPU only) 515.65.01
• Issue Type( questions, new requirements, bugs) Maybe bug
I’m getting output videos with unexpected minor “vibration” (apologies for not able to explain it precisely, but should be easy to notice if you watch and compare the attached video files), only when using NvDCF
tracker and setting nvinfer
interval > 0.
Model: PeopleNet deployable_quantized_v2.6
Config:
config_infer_primary_peoplenet.txt
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
tlt-model-key=tlt_encode
tlt-encoded-model=/host/test/peoplenet/resnet34_peoplenet_int8.etlt
labelfile-path=/host/test/peoplenet/labels_peoplenet.txt
model-engine-file=/host/test/peoplenet/resnet34_peoplenet_int8.etlt_b1_gpu0_int8.engine
int8-calib-file=/host/test/peoplenet/resnet34_peoplenet_int8.txt
input-dims=3;544;960;0
uff-input-blob-name=input_1
batch-size=1
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
num-detected-classes=3
cluster-mode=2
interval=0
gie-unique-id=1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
#Use the config params below for dbscan clustering mode
#[class-attrs-all]
#detected-min-w=4
#detected-min-h=4
#minBoxes=3
#eps=0.7
#Use the config params below for NMS clustering mode
[class-attrs-all]
topk=20
nms-iou-threshold=0.5
pre-cluster-threshold=0.2
## Per class configurations
[class-attrs-0]
topk=20
pre-cluster-threshold=0.4
#[class-attrs-1]
#pre-cluster-threshold=0.05
#eps=0.7
#dbscan-min-score=0.5
Input video:
- NvDCF tracker + nvinfer interval=1 = vibration
gst-launch-1.0 \
uridecodebin uri="file:///host/test/record.mp4" ! m.sink_0 \
nvstreammux name=m batch-size=1 width=1920 height=1080 \
! nvinfer \
config-file-path=/host/test/peoplenet/config_infer_primary_peoplenet.txt \
interval=1 \
! nvtracker \
ll-lib-file=/opt/nvidia/deepstream/deepstream-6.1/lib/libnvds_nvmultiobjecttracker.so \
ll-config-file=/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_tracker_NvDCF_max_perf.yml \
! nvvideoconvert \
! nvdsosd \
! nvvideoconvert \
! nvv4l2h264enc bitrate=4000000 \
! h264parse \
! mp4mux \
! filesink location="/host/test/nvdcf_interval1_vibration.mp4"
And all of the below pipelines produce normal videos with no vibration.
NvDCF tracker + nvinfer interval=0
gst-launch-1.0 \
! nvinfer \
interval=1 \
! nvtracker \
! nvvideoconvert \
! nvdsosd \
! nvvideoconvert \
! h264parse \
! mp4mux \
! filesink location="/host/test/nvdcf_interval0_novibration.mp4"
IOU tracker + nvinfer interval=0
gst-launch-1.0 \
! nvinfer \
interval=0 \
! nvtracker \
ll-config-file=/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_tracker_IOU.yml \
! nvvideoconvert \
! nvdsosd \
! nvvideoconvert \
! h264parse \
! mp4mux \
! filesink location="/host/test/iou_interval0_novibration.mp4"
IOU tracker + nvinfer interval=1
gst-launch-1.0 \
! nvinfer \
interval=1 \
! nvtracker \
! nvvideoconvert \
! nvdsosd \
! nvvideoconvert \
! h264parse \
! mp4mux \
! filesink location="/host/test/iou_interval1_novibration.mp4"
No tracker + nvinfer interval=0
gst-launch-1.0 \
! nvinfer \
interval=0 \
! nvvideoconvert \
! nvdsosd \
! nvvideoconvert \
! h264parse \
! mp4mux \
! filesink location="/host/test/notracker_interval0_novibration.mp4"
No tracker + nvinfer interval=1
gst-launch-1.0 \
! nvinfer \
interval=1 \
! nvvideoconvert \
! nvdsosd \
! nvvideoconvert \
! h264parse \
! mp4mux \
! filesink location="/host/test/notracker_interval1_novibration.mp4"
