Mint 19 crashes with NVIDIA drivers 390 or 340 and GeForce GT630
e.g.
[url]https://www.techpowerup.com/vgabios/158993/158993[/url]
Edit: there are also bios sanitizers so you can reflash your own bios.
Thank you - I get PCI Subsystem ID 10B0.1284 does not match adapter PCI Subsystem ID 1569.1284
What are bios sanitizers? Where do I get them?
NVFLASH WORKED!!! :-)
Thank you so mach!! :-)
use nvflash to copy your current vbios to disk.
Download nibitor or similar and run it in wine, open the vbios file, it should correct the checksum (don’t know exactly), save it to disk, then flash using nvflash.
For your card, you’ll have to use keplerbiostweaker or the like.
Did you just reflash, or force flashed the downloaded image?
The solution for me was to do
nvflash_linux -6 vbios.rom
where -6 overrides the subsystem mismatch and vbios.ros is the firmware file you linked me to.
After that I installed the nvidia 390 driver as I did previously and it works fine (even games and OpenGHL 4.6).
Thanx!
