MIPI acquisition dropping frames
I am bringing up a new specialized camera sensor connected to the CSI connector on the bottom of a Jetson Orin devkit and I am seeing errors in the kernel logs about the discarded frames and I am hoping someone can help me determine the root cause of the CHANSEL_SHORT_FRAME events in the kernel traces that I am seeing. I have double checked the values in the device tree for the sensor and confirmed that they match the sensor and that csi_pixel_bit_depth="16", active_w="1024", active_h="1024", line_length="1064" (with horizontal blanking), mode_type="yuv", pixel_phase="yuyv", pix_clk_hz="40000000", embedded_metadata_height="0" are all correct. Is it possible to bypass the CRC checks and examine the raw data for errors on the Jetson.
I am using v4l2-ctl to read from the device:
root@orin:~$ v4l2-ctl -d /dev/video0 --verbose --set-fmt-video=width=1024,height=1024,pixelformat=YUYV --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test_frame.raw
VIDIOC_QUERYCAP: ok
VIDIOC_S_EXT_CTRLS: ok
VIDIOC_G_FMT: ok
VIDIOC_S_FMT: ok
Format Video Capture:
        Width/Height      : 1024/1024
        Pixel Format      : 'YUYV' (YUYV 4:2:2)
        Field             : None
        Bytes per Line    : 2048
        Size Image        : 2097152
        Colorspace        : sRGB
        Transfer Function : Default (maps to sRGB)
        YCbCr/HSV Encoding: Default (maps to ITU-R 601)
        Quantization      : Default (maps to Limited Range)
        Flags             :
                VIDIOC_REQBUFS returned 0 (Success)
                VIDIOC_QUERYBUF returned 0 (Success)
                VIDIOC_QBUF returned 0 (Success)
                VIDIOC_STREAMON returned 0 (Success)
cap dqbuf: 0 seq:      0 bytesused: 2097152 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
cap dqbuf: 1 seq:      1 bytesused: 2097152 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
cap dqbuf: 2 seq:      2 bytesused: 2097152 ts: 0.000000 (error, ts-monotonic, ts-src-eof)
and I see the following output in the kernel logs (5.15.185-rt-tegra):
[ 1160.612123] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 1160.640442] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 1160.668912] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
[ 1160.697359] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 131072
When i enabled tracing in the kernel with the commands below I was able to capture trace.log (74.9 KB) where I found CHANSEL_SHORT_FRAME entries.
sudo su
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace_pipe
I was able to add some extra log messages to vi5_fops.c to also output the status and notify_bits
but I have been unable to understand exact details on the error.
CHANSEL_SHORT_FRAME tell the output size don’t expected.
Do you boost the clocks to confirm.
sudo su
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee  /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
I tried with booted clock but got the same issue.
capture_output.txt (4.0 KB)
Is there a way to see the actual number of bytes received from the sensor? That information could help me understand if its a few bytes off, a few lines off, or even confirm that the sensor is sending fixed sized frames.
No,
But you can modify the driver to reduce the height to narrow down it.
After testing a few different configurations I was able to get an image to read from an FPGA test pattern generator connected to the same CSI port but I now have two questions.
  1. Im guessing my original issue stemmed a mismatched format header: RAW16 output from the sensor while the Jetson was configured to expect a 16 bit yuv format. The question I have is will the Orin or the onboard Falcon processor drop the frame if there is a configuration mismatch even if we are bypassing the ISP and reading via V4l2?
  2. Using an FPGA based test pattern generator connected to the same CSI port I have been testing multiple formats. The first that I was able to get working was:
Width Height Horizontal Blanking
(Pixels)
Pixel Clock
(Mhz)
Pixel
Format
Bit
Depth
3840 2160 256 40MHZ RGB888 24
This yielded frames of 33177600 bytes with each pixel represented by 4 bytes. Then when I attempted to generate a smaller test frame that matched one of my sensors:
(Pixels)
Pixel Clock
(Mhz)
Pixel
Format
Bit
Depth
1620 1240 256 40MHZ RGB888 24
I got another timeout error reading from the device. From what I tested and could find on the forums it seems there is either a 64-byte alignment (and/or maybe a 256-byte alignment) requirement for the Jetson to read an image. Can you confirm if there is such a byte alignment requirement and if so how to calculate the frame size/horizontal blanking pixels needed to align the lines/frame?
  1. No the NVCSI/VI don’t check the format to drop the frame.
  2. You can set the preferred_stride by v4l2-ctl like below for the 256 alignment.
v4l2-ctl -c preferred_stride=1792
