过mipi c-phy方案
想请问一下老师ORIN套件是否支持mipi c-phy方案。
双ORIN的板子是否具备I2S的从机功能。
Oin support C-phy. you can refer to OEM design guide for details. https://developer.nvidia.com/embedded/secure/jetson/agx_orin/jetson_agx_orin_design_guide_dg-10653-001_v0.2.pdf
I2S is initialized as host and not recommended to be slave, would u mind to share your purpose on this connection?
We have PCIE/Ethernet/UART/I2C/SPI. they are all able to be active as slave or endpoint to transfer data between two or more jetson.
Thank you
我们这是使用的双ORIN方案,所以想使用I2S来进行一个主从机的连接。
也就是说I2S是没办法进行的是吗?
We support I2S Slave mode, but depends on your effort to do the driver porting. We don’t have a chance to do the verification.
Thank you
