Hi All,
We are trying to develop sensor driver code for hdmi2csi adapter. But we get some error related to Mipi caliberation.
2199.312187] tegra_mipi_cal 3990000.mipical: tegra_mipi_bias_pad_enable
[ 2199.319908] tegra_mipi_cal 3990000.mipical: tegra_mipi_calibration
[ 2199.824805] tegra_mipi_cal 3990000.mipical: Mipi cal timeout,val:8771, lanes:c00000
[ 2199.832535] tegra_mipi_cal 3990000.mipical: Fixed clk 68MHz
[ 2199.838278] tegra_mipi_cal 3990000.mipical: MIPI_CAL_CTRL 0x04 0x2a000010
[ 2199.846648] tegra_mipi_cal 3990000.mipical: CIL_MIPI_CAL_STATUS 0x0c 0x00008771
[ 2199.855021] tegra_mipi_cal 3990000.mipical: CIL_MIPI_CAL_STATUS_2 0x10 0x00000000
[ 2199.863374] tegra_mipi_cal 3990000.mipical: CILA_MIPI_CAL_CONFIG 0x18 0x00000000
[ 2199.871706] tegra_mipi_cal 3990000.mipical: CILB_MIPI_CAL_CONFIG 0x1c 0x00000000
[ 2199.880023] tegra_mipi_cal 3990000.mipical: CILC_MIPI_CAL_CONFIG 0x20 0x00200000
[ 2199.888342] tegra_mipi_cal 3990000.mipical: CILD_MIPI_CAL_CONFIG 0x24 0x00200000
[ 2199.896655] tegra_mipi_cal 3990000.mipical: CILE_MIPI_CAL_CONFIG 0x28 0x00000000
[ 2199.904959] tegra_mipi_cal 3990000.mipical: CILF_MIPI_CAL_CONFIG 0x2c 0x00000000
[ 2199.913259] tegra_mipi_cal 3990000.mipical: DSIA_MIPI_CAL_CONFIG 0x3c 0x00000200
[ 2199.921556] tegra_mipi_cal 3990000.mipical: DSIB_MIPI_CAL_CONFIG 0x40 0x00000200
[ 2199.929848] tegra_mipi_cal 3990000.mipical: DSIC_MIPI_CAL_CONFIG 0x44 0x00000200
[ 2199.938141] tegra_mipi_cal 3990000.mipical: DSID_MIPI_CAL_CONFIG 0x48 0x00000200
[ 2199.946437] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG0 0x5c 0x00000000
[ 2199.954726] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG1 0x60 0x00000000
[ 2199.963019] tegra_mipi_cal 3990000.mipical: MIPI_BIAS_PAD_CFG2 0x64 0x00010010
[ 2199.971306] tegra_mipi_cal 3990000.mipical: DSIA_MIPI_CAL_CONFIG_2 0x68 0x00000002
[ 2199.979584] tegra_mipi_cal 3990000.mipical: DSIB_MIPI_CAL_CONFIG_2 0x6c 0x00000002
[ 2199.987851] tegra_mipi_cal 3990000.mipical: DSIC_MIPI_CAL_CONFIG_2 0x74 0x00000002
[ 2199.996127] tegra_mipi_cal 3990000.mipical: DSID_MIPI_CAL_CONFIG_2 0x78 0x00000002
[ 2200.004427] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_s_stream():
[ 2201.008844] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2202.012858] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2203.016901] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2204.020915] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 2205.024959] tegra-vi4 15700000.vi: ATOMP_FE syncpt timeout!
[ 2205.031035] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_s_stream():
[ 2205.036822] tegra_mipi_cal 3990000.mipical: tegra_mipi_bias_pad_disable
[ 2205.052354] fpga_hdmi2csi 0-003c: fpga_hdmi2csi_s_power()
thanks in advance…
