Hi NVIDIA Team,
We are developing a custom Jetson Thor carrier board named N*** and would like to validate the signal integrity of its MIPI CSI-2 D-PHY interface.
Our camera signal path is:
Camera module → GMSL serializer → MAX96712 deserializer → carrier-board MIPI traces → module connector → Jetson Thor CSI receiver
We would like to evaluate the received signal quality after the carrier-board traces, preferably using software-based internal eye scanning, receiver margin measurements, or error monitoring.
Our configuration is:
- Jetson module: [Jetson T5000 128GB]
- JetPack / Jetson Linux version: [7.1-b112/R38.4.0]
- Deserializer: MAX96712GTB/V+T
- D-PHY data rate: [2.5Gbps lane]
We would like to ask:
- Does the Thor NVCSI D-PHY receiver support an internal eye scan, Eye Opening Monitor, or timing/voltage margin measurement?
- Is the UPHY EOM described in the Jetson Thor I/O Verification Guide applicable to MIPI CSI, or is a separate CSI diagnostic tool required?
- If supported, could you provide the required tools, commands, BSP requirements, and result interpretation criteria?
- Can a real camera stream or a MAX96712 test pattern be used for these measurements? Is there any supported internal BER test or pattern checker?
- If internal eye scanning is unavailable, which CSI/VI error counters and validation procedures do you recommend for assessing receiver signal integrity?
Any recommended documentation or reference scripts would be appreciated.
Thank you.
